O2 sim that works (Mod Edit: read the thread, it doesn't work)
Old Mar 18, 2008 | 08:22 PM
tfblkhwkce's Avatar
TFBLKHWKCE
ok first i should let you know this isn't an O2 sim but another way to get the same effect. some guys want to take out or gut a cat out and a couple exhaust systems come complete with a race/cat-delete pipe, i have the exoticspeed headers all the way back. Ive read a couple of threads on here about O2 sims and how they don't work and if the do your lucky. well i found a way around it where you don't have to cut any wires. i don't know if this is new or not but i haven't seen it on here.
well what i did was this:
step 1- went to my local auto parts store
step 2- got a HELP! part #42009. this is a spark plug non-fouler.
step 3- open the package....ill stop with the steps
the idea is to block most of the exhaust from the O2 sensor. the non-fouler needs to be drilled out for the O2 sensor to fit. i used a 31/64th inch drill bit but half inch might work too. the spark plug non-fouler is threaded on the inside for the O2 sensor and the end is threaded on the outside to fit in the pipe. you drill it out...thread the O2 sensor in tight...then thread the whole assembly in where the O2 sensor would in the race/cat-delete pipe. then reset your pcm and that should be it.
my friend has a CEL code reader so after a couple days of driving and the car going through many drive/catalyst cycles we checked to see if there were any codes pending....it said catalyst ok and i haven't had a CEL yet and i don't think i will. but if i do and if anyone else tries this then just add another non-fouler to decrease the amount of exhaust gases the O2 sensor reads. i have one on and my O2 sensor sticks out about an inch more than it does normally but has plenty of room.
Old Mar 18, 2008 | 10:51 PM
gregs's Avatar
Pull My Finger
interesting, i think im going to have to try this, im tired of seeing my cel on
Old Mar 18, 2008 | 10:54 PM
chancejat's Avatar
Drive it like u stole it!
i tried something similar and got a code saying "o2 sensor slow response"...i guess your just lucky...
Old Mar 19, 2008 | 03:21 AM
tfblkhwkce's Avatar
TFBLKHWKCE
well the O2 sensor needs to read some but not all the exhaust gases to register. if you drill out the spark plug non-fouler too much then you will get the CEL..same as if you dont drill enough the sensor wont read any of the exhaust gases. maybe i got lucky when i use a 31/64th inch bit...maybe thats the magic size. if it doesnt work right off the bat for you like it did for me then play with it...get it to work. i mean the part only costs like $5...alot less then any O2 sim.
Old Mar 19, 2008 | 08:58 AM
Greenblurr93's Avatar
Sotally Tober
Good info, there has been people here talking about using plug foulers, but from what i remember, they didnt drill it. Sometimes it takes a few days for a CEL to come one after gutting the cat... id be interested in seeing if youre still not throwing codes after a week or so.
Keep us updated!
Old Mar 19, 2008 | 09:01 AM
heyarnold69's Avatar
Rotary wanabee
ive doen this before... you need 2 of them and it works like a charm
Old Mar 19, 2008 | 09:07 AM
mysql's Avatar
Doppelgänger
it can take several drive cycles to register a malfunctioning cat.
Just get the cobb accessport and delete the cat CEL so it doesn't show up, instead of hardware trickery.
Old Mar 19, 2008 | 09:12 AM
Sotally Tober
I'm plaaning on gettin AP as soon as my Stimulous check comes in, but for now, this may get me by
Old Mar 23, 2008 | 10:44 AM
tfblkhwkce's Avatar
TFBLKHWKCE
why buy the AP for $600 when you can buy that part for $5. plus you dont have to clear your codes every day.
Old Mar 23, 2008 | 10:49 AM
chancejat's Avatar
ap deletes the code for good...
Old Mar 23, 2008 | 11:11 AM
Sotally Tober
Yeah, AP can disable CEL codes, and allow diff fuel and timing maps... So its not just a O2 delete, its a tuning tool.
Old Mar 23, 2008 | 04:44 PM
matthew121's Avatar
I think I'll try the 10$ method, instead of the 600$
Old Mar 23, 2008 | 05:02 PM
mysql's Avatar
Doppelgänger
I have yet to see a trick method that can fool the rx-8 pcm
Old Mar 24, 2008 | 11:51 AM
matthew121's Avatar
yea, but if there is a slight chance it might ( as in these few people who it has worked for) I am still willing to give it a shot.
Old Mar 24, 2008 | 03:00 PM
tfblkhwkce's Avatar
TFBLKHWKCE
i just might have to check that AP out! but this little trick is working for me. every time we read if any codes are pending it says catalyst ok.
Old Mar 24, 2008 | 03:45 PM
Georgia8er's Avatar
Question: when the pcm throws a CEL for the cat, does it run in open loop only?
Old Mar 24, 2008 | 04:05 PM
Sotally Tober
no, it still should be making adjustments as per the primary wideband o2 sensor... the secondary is there to make sure the cat is doing its job...
Old Mar 25, 2008 | 08:13 AM
r0tor's Avatar
because then you also get fuel maps that will actually let your $1000 exhaust make power?
Old Mar 25, 2008 | 11:08 AM
Georgia8er's Avatar
I don't disagree with you, but I wondered if anyone had checked it with a scan tool to be sure. I know older vehicles would sometimes go into open loop for any code that lit the CEL.
Old Mar 25, 2008 | 11:18 AM
Sotally Tober
new PCM's can tell if its puttin the motor at risk, if its not, then it wont (shouldnt) go into open loop
Old Mar 27, 2008 | 01:39 AM
get back to us..
we love fail!!!! after the one you are going to try. i can give # 2..
Old Mar 27, 2008 | 02:06 PM
matthew121's Avatar
I spend more than 10$ on a drink at the bar,
its worth a shot to me, I am going to try it today
Old Mar 27, 2008 | 02:12 PM
Sotally Tober
Good luck, report back in about a week of normal driving and let us know if the CEL ever came on
Old Mar 27, 2008 | 04:32 PM
tfblkhwkce's Avatar
TFBLKHWKCE
well its been a couple weeks and a couple hundred miles or so and still my cat code is good.
Old Mar 27, 2008 | 05:00 PM
Sotally Tober
thats very promising.... thanks for the update!
