question about driving stick
Old Mar 16, 2008 | 08:17 PM
beast53's Avatar
say your going at around idle speed on 2nd gear around a parking lot (or your driveway into a garage) looking for a spot. When you finally find one, given that you use the brakes to position yourself in the spot, do you pull in while ur still in 2nd going idle speed/using the clutch or do you go to first and use the clutch? sometimes when im pulling into my garage i just try to stay in idle speed in 2nd but i stall out. maybe its because my driveway is uphill?
thanks
Old Mar 16, 2008 | 08:19 PM
mysql's Avatar
Doppelgänger
If you're under 6 mph or so, shift into 1st.
Old Mar 18, 2008 | 11:32 AM
JRichter's Avatar
Void Where Prohibited
I press the clutch in completely once I've started rolling into the spot, then put the car in first with the clutch still pressed in and if not enough momentum, slowley let off/ride the clutch until the car gets into the desired position.
If your stalling in second, try first for sure.
Old Mar 18, 2008 | 11:34 AM
laythor's Avatar
I zoom therefore I am.
if you're parking and going uphill you should be going less then 6mph, use first gear.
Old Mar 18, 2008 | 12:11 PM
Rootski's Avatar
DGAF
You will know, Grasshopper. When the time comes, you will know.
Old Mar 18, 2008 | 12:20 PM
EdwardsB's Avatar
Registered RX-8 User
I do exactly as jrichter does, it works and will solve your prob
Old Mar 18, 2008 | 07:22 PM
YaXMaNGTO's Avatar
It's a Cavalier
No, no, no... you're doing it wrong. Here's an instructional video.
http://www.youtube.com/watch?v=P71m3LFmLO0
Old Mar 18, 2008 | 07:34 PM
TopGear8's Avatar
mkuhnracing.com
^Yeah he's right. Just go about 30+ mph. pop it in neutral pull the ebrake. Works every time
05TR1CH
Apr 18, 2023 04:56 AM
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
PlayInMyWoods
Aug 8, 2015 07:03 AM
xandersonx97
Aug 2, 2015 01:02 AM
