tail light filling with water and condensation - HELP!
Old Feb 26, 2008 | 03:05 PM
allosaur's Avatar
My right tail light has lots of condensation in it. Also, I just took it to the car wash and it seems to have filled up a bit with water. I've noticed this problem in some other RX-8s I've seen on the road. Is this a manufacturer defect? Suggestions? I'm pretty much a noob when it comes to cars. Thanks.
Old Feb 26, 2008 | 03:20 PM
987HYS's Avatar
Dragon Certified
If your car is still under warranty, the dealership will fix it. its a common problem, and its a bad gasket in the housing that needs replacing. search for more info
Old Feb 26, 2008 | 03:21 PM
laythor's Avatar
I zoom therefore I am.
it's a common problem on older 8's
search and you'll find the TSB about it
dealer should replace them for you
XLR83N's Avatar
take it to mazda under warranty, if not, umm take the light out and try to find the leak and seal it some how or just buy a new tail light
Old Apr 30, 2008 | 07:01 AM
Minotavr's Avatar
Less Fast, More Furious
Gasket
Replace the gasket ! It's by far the worst thing in an RX-8 !
Old Apr 30, 2008 | 07:11 AM
expo1's Avatar
He's as bad as Can
If you warranty is still valid go there while the condensation is still there. If the dealer doesn't see it they might not order you a new one.
Old Apr 30, 2008 | 07:28 AM
crimson-rain's Avatar
minotavr, is it possible to order a new gasket for the tailight? I'm on my 2nd tail light and I'm out of warranty period.
Old Apr 30, 2008 | 09:01 AM
Minotavr's Avatar
Of course it is, unfortunately I can't give you the code# for the gasket. But any dealer should know that.
Old Apr 30, 2008 | 09:54 AM
midlifer's Avatar
If your 8 is not under warranty then you can buy the gasket and do it yourself.
http://www.finishlineperformance.com...cat=302&page=1
Bob
Old Apr 30, 2008 | 10:17 AM
m3pkrobert's Avatar
drill a small hole in the bottom and it will b fix
Old Apr 30, 2008 | 07:11 PM
Bob
sweet. and I live relatively close by (I get my 8 serviced there and everyone there in the service department is AWESOME).
Old Apr 30, 2008 | 07:27 PM
rled's Avatar
5Picker
My tail light did the same thing. I bought the Mazda gasket, which is stupid expensive, It is just a bit thicker than the original which is just a piece of foam of some sort .Most likely the water is running in at the top of the tail light right below where the water drains off the trunk lid. There is good info on how to remove the tail light right here on the forum. Take it out , dry the water out . I used compressed air, but there are other ways. Get you some clear silicone sealer and put a small bead of the silicone on the rear panel where the gasket contacts the panel.Put your tail light back in and no more water. Hope this helps .
Old Apr 30, 2008 | 07:54 PM
05rex8's Avatar
sold the 8... :(
+1 did this and no issues
Old Apr 30, 2008 | 08:06 PM
nuke0907's Avatar
Never Blend In
.....so far.
just get the gasket from finishline. the hole might seem to help but it does not fix the problem which is the gasket.
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Aug 29, 2018 10:14 AM
Azki23
Jun 27, 2018 03:48 PM
RXFEVER
Sep 11, 2016 02:51 PM
