Sqeaky when cold
Old Nov 3, 2003 | 04:30 PM
Gyro 2's Avatar
Sqeaky when cold
I have noticed over the last week, a squeak from the engine compartment as I drive when cold. This lasts for only a second while a go into first as I drive away.
Very quiet but never the less noticable to me.
I'm thinking......happens only when cold, only for a second or two.... BELT!
The belts must have stretched a tiny bit over the last 3700 miles. Also there is no pretentioner that I can see. The adjustment is manual. There are two belts. The wider of the two drives the alternator. My scientific method of determining which one I would adjust came down to which one felt looser.
The Alternator belt has a tiny bit less tension by touch. I figured I would only adjust a small amount so that even if that belt was not the culprit, the extra tension was a mute point.
The adjustment was very easy. A 12 mm socket is all that is needed.
First just "crack" the bolt on the slide. Then turn the adjuster bolt a few times. I only moved it 1/8 of an inch from its original position.
I will know in the morning if this was the problem.
Old Nov 3, 2003 | 04:32 PM
Gyro 2's Avatar
You can see how much adjustment was made in this pic.
Gyro 2's Avatar
this is the adjustment bolt.
Old Nov 3, 2003 | 04:57 PM
wakeech's Avatar
mostly harmless
you rule. thanks for the pics.
Old Nov 3, 2003 | 05:04 PM
my10ae's Avatar
Moderator
Thanks for the tip. Something to keep an eye on here now that winter is just around the corner here in NH.
Old Nov 4, 2003 | 03:04 PM
syntrix's Avatar
I like cheese!
Did that cure the problem this morning?
mdl0209
May 23, 2019 05:46 PM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Jb4ker96
Sep 27, 2015 10:06 PM
