New player in BS....
Old Feb 20, 2008 | 05:07 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
http://scca.org/documents/Fastrack/0...k-mar-solo.pdf
Nismo 350Z is in BS.
Old Feb 20, 2008 | 05:19 PM
mwood's Avatar
306hp and 268lb/ft...with 90% torque at 2000rpm. 18x9 and 19x10 wheels (!!). And, a stiffer spring package than the track model...all sounds good.
But, 3350lbs (so, maybe 3250 prepped?) and almost 2" wider than the '8.
I know, let's give one to Carter and see what happens!
Old Feb 20, 2008 | 05:21 PM
ULLLOSE's Avatar
When we had the vote I said only if Carter is not allowed to drive one.... Somehow that did not make it into FasTrack, I will get a clarification printed next month.
Old Feb 20, 2008 | 05:31 PM
mwood's Avatar
I'll tell you one thing...if the Nismo becomes "the" car for BS, we've just gone past AS in terms of "pay to play"...$40,000 for the car and $1400/set for tires...might as well go run SS in a C5 Z06 or Elise, it would be cheaper.
Old Feb 20, 2008 | 05:40 PM
PedalFaster's Avatar
How does the Nismo's weight, wheel size, and power compare to, say, a BSP C4 Vette's?
I recognize that there are significant differences between the cars (like, say, a working diff), but I'm curious.
While I disagree with the decision, to play devil's advocate -- even if the Nismo ends up being a bit faster than the RX-8, it'll be a lot harder to get those times out of that big and powerful of a car than it is to get them out of the RX-8.
Old Feb 20, 2008 | 05:50 PM
chiketkd's Avatar
Row faster, I hear banjos
Well this sets the stage for the '09 RX-8 to be in BS...and possibly the future model with the 16X Renesis.
Old Feb 20, 2008 | 05:54 PM
tomsn16's Avatar
There is little worry re Carter getting a Nizmo Z ( unless as Mike suggests,someone gives him one).
We could be wrong, but still think the Z would make a nice FS car, particularly the Nizmo.
Old Feb 20, 2008 | 05:58 PM
chiketkd's Avatar
The Z doesn't fit the 'spirit' of the FS class. Carter proved it can compete in BS and it would be a shame if the car is ever moved.
Old Feb 20, 2008 | 06:11 PM
mwood's Avatar
Man, them's some fat tires on that gray RX8
Old Feb 20, 2008 | 06:26 PM
delhi's Avatar
Grand Chancellor
so what class is the regular Z? I'm not familiar with US SCCA classifications.
Old Feb 20, 2008 | 06:38 PM
mp5's Avatar
mp5
BS as well.
Old Feb 20, 2008 | 07:08 PM
tomsn16's Avatar
Yea, we finally squeezed on some 295's .......not.
Old Feb 20, 2008 | 07:42 PM
mwood's Avatar
295? I thought those were the 315/30's you said you were sure were going to fit?
You guys try the MaxQ, yet?
Old Feb 20, 2008 | 08:01 PM
those specs look more like an AS Corvette to me
Old Feb 20, 2008 | 08:43 PM
tucker1170's Avatar
I thought that the Z's biggest issue was that it couldn't get enough camber on the steer tires to make all that weight want to turn. I wonder if the Nismo version would be any different???
Old Feb 20, 2008 | 08:58 PM
tomsn16's Avatar
MaxQ not setup yet. My IT man ( Carter ) is a little slow and we may have a problem with my Pocket PC ( Dell Axim X51), haven't been able to download MaxQ program yet. Been concentrating on getting car ready for the Dixie,plenty of time later to crank up the Q.
Old Feb 20, 2008 | 09:21 PM
ULLLOSE's Avatar
I would not compare a stock car to an SP car. My AS L98 C4 did 233 hp and 322 tq (about 300 lbs of tq from 1800rpm on) at the wheels, 3210lbs. The C4 is also an A arm car, not a McCrutch car, so the front works better. On top of that the C4 has a working LSD with 9.5" wide wheels front and rear.
Move up to a LT4 vette and you are around 300 hp at the wheels and about the same tq as mine was, but further up the power band. You also get a 11" wide rear wheel. The down side, about 150lbs more weight and softer springs.
Has anyone shown the newer Z to be better than the older one that Carter did so well in?
Old Feb 20, 2008 | 09:34 PM
mwood's Avatar
Glen Austin has gone quickly in his Z...isn't it a newer model?
Old Feb 20, 2008 | 09:51 PM
ULLLOSE's Avatar
Same as Carter's..... Even down to the color.
Old Feb 20, 2008 | 09:58 PM
chiketkd's Avatar
So Glen is in an '05 Track model?
Jim (tomsn16), will you and Carter be getting down in time to do the T&T on Friday? Looking forward to meeting a bunch on you guys in a few days...
Old Feb 20, 2008 | 10:36 PM
mwood's Avatar
I did not know that...doh!!
Old Feb 21, 2008 | 12:50 AM
Cooper47's Avatar
We had a Nismo at our shop for a while....It was pretty impressive. They're special cars. Pulled from the line up and spot welded for rigidity and all that. It's more then just a pretty car. For sure someone is going to buy one, set it up for BS and then stick in a hotshoe for Nationals.
Still, the weight doesn't change and to me that's the RX8's biggest advantage. But yeah, that's definately a contender at the end of year in my book.
Old Feb 21, 2008 | 01:22 AM
tomsn16's Avatar
Yep Glen's Z is an '05 Track,same as ours.
We don't arrive Dixie till late Friday evening.Will see you in grid.
Jim and Carter
Old Feb 21, 2008 | 06:17 AM
John V's Avatar
Not ******
The Z's front suspension isn't McStruts.
Old Feb 21, 2008 | 07:37 AM
chiketkd's Avatar
Jim and Carter
Cool. See you guys in grid!
Chike #70
