RX-8 Media News Report the latest RX-8 related news stories here.
This is the best artical on the RX-8
Old Nov 1, 2003 | 09:27 PM
noahclark1304's Avatar
RX-8
This may be on a tread but still good.
Old Nov 6, 2003 | 11:45 PM
Geek's Avatar
Cool
Cool site Thks....
Old Nov 7, 2003 | 12:12 AM
syntrix's Avatar
I like cheese!
It's ok.
One Paragraph contradicts itself:
But downshifting is redefined by the rotary engine, not to mention the brilliant close-ratio six-speed gearbox. You can drop the RX-8 into second gear at a speed that would cause almost every other car on the planet to scream, if not explode.
A close ratio WOULD make the gearbox explode! I think they got the name "close-ratio" wrong, or got the comparison backwards.
Also, they don't say how downshifting is actually "redefined" by the rotary engine. Screwy.
I'd give the review 4 out of 10 stars. Less if you include their blank "mod section".
Old Nov 17, 2003 | 09:13 PM
BoomerBurt's Avatar
The "close ratio" point is that there is not a large jump from gear to gear, so down-shifting at speed for stronger acceleration will not cause the rev's to jump up too high and damage things. I think it is a valid point, and a significant point for an engine with relatively low torque.
No, it doesn't explain the "redefinition" thing, but I would guess that the fact that the rotary will rev quickly is what makes downshifting better than in a piston-engined car. I'm not sure I would defend this as "redefined", but it does work better.
Old Nov 18, 2003 | 06:21 PM
RX8FanMan's Avatar
JRizzle
they have a pretty good selection in their wallpapers, why don't they have titanium?
Old Nov 18, 2003 | 06:25 PM
syntrix's Avatar
I like cheese!
There is a large jump from gear to gear.
If the gear box was close ratio, you might only have to 2x clutch 1500 rpms on a downshift.
If the gear box was wide/economy/etc you might have to downshift 3500 rpm per gear.
IMHO the gearbox is not close-ratio. Especially if you have driven earlier cars with close ratio gear boxes. Why am I speeding on the freeway in 2nd gear?
In a close ratio, I should have to be in 4th, and it would make better use of the 6 speed.
I've been wondering about a higher ratio ring & pinion for a while, and I think this would be the best damn mod for the car!
Old Nov 19, 2003 | 08:56 AM
Omicron's Avatar
Yeah, what's up with that? I couldn't even get into the "Submit your RX-8" section!
Because the car has a 9000 RPM redline :D
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
arexatemate
Oct 9, 2015 06:23 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
