smallest wheel size for snow tires
Old Feb 6, 2008 | 08:11 AM
jasondeal's Avatar
can i use a 15 inch wheel for snow tires?
thanks
Old Feb 6, 2008 | 08:22 AM
DarkBrew's Avatar
Extraordinary Engineering
Some information about your car would be helpful!
If you have the MT (18" summer wheels) then your smallest winter wheel is 17"
Old Feb 6, 2008 | 09:44 AM
lilring's Avatar
Finally a MT
skinner the wheel is the better it is.
Old Feb 6, 2008 | 11:01 AM
jasondeal's Avatar
05 MT stock 18" wheels. I just moved to colorado from florida, and that should pretty much explain the ignorance to the snow. I figured it would be cheaper if i could go to a steel wheel for the winter but it's seeming to be a bit more difficult than i thought.
thanks
Old Feb 6, 2008 | 11:23 AM
DarkBrew's Avatar
Most owners get a cheap 17"x7" alloy wheel with 215 55 17 or 225-50-17 snow tires. Many tire shops such as www.tirerack.com have packages.
18" snow tires cost much more than 17" and the wheels allow you to swap back and forth without spending money at a tire shop.
Old Feb 6, 2008 | 11:30 AM
Huey52's Avatar
Registered Zoom Zoomer
Going with 17" wheels for Winter snow tires also affords a taller sidewall which is advantageous. As DarkBrew cites, TireRack has some very reasonable wheel/snow tire packages.
Or - you may want to consider going to an All Season tire on your stock rims.
"...as for the best [All Season] traction i would recommend the following ....
225/45R18 Goodyear Eagle F1 AS -- 162.00
To help your order process faster please reference Connor @X269 when placing an order over the internet or give me a call directly. This way i can try and head off any problems and help expedite your order.
Thanks and have a great day,
Connor
Tire Rack Performance parts specialist
877-522-8473 X269"
Old Feb 6, 2008 | 01:54 PM
If u have MT, 17 is the lowest you can go without destroying everything.
Old Feb 12, 2008 | 02:19 PM
KeithL's Avatar
mmmmm, Pale Ale!
nycgps - why is it the smaller wheels would hurt the MT?
For the o/p -
I bought some 17 x 7 painted aluminum wheels (cheaper than I could find any used OEM wheels), and some Continental 215/55R17 snows from Tire Rack.
Definitely worth the $$. Last winter we had very little snow, and the stock tires scared the s**t outta me. This year we had the biggest accumulation in a single storm in 15 years - a little over 8" (this is St. Louis). I had absolutely no problem in that storm. If I were you, I'd go for a set of dedicated snows.
Old Feb 12, 2008 | 02:28 PM
EdwardsB's Avatar
Registered RX-8 User
^ it wont fit over your front calipers and rotors
Old Feb 12, 2008 | 03:02 PM
KeithL's Avatar
mmmmm, Pale Ale!
Ah right - forgot the 6 port motor comes w/ the bigger front brakes...
ouimetnick
25
Sep 14, 2023 01:44 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
bullbuchanan
26
Mar 24, 2016 12:37 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
Brandonien
Jul 30, 2015 12:33 PM
