DIY: Clutch Pedal Extension
Old Oct 31, 2003 | 05:03 PM
Omicron's Avatar
Clutch pedal Extension instructions with Pics
For those of you, like me, who find the driving position in the RX-8 uncomfortable due to the gas pedal being too close, I have worked out a solution.
After much carefully controlled scientific experimentation, (ok, ok, with a small piece of 2x4 lumber and some duct tape!) I was able to determing that if I could extend the clutch pedal about 1.5 inches, I could comfortably depress it with the seat back where I like to have it. This also allowed me to extend my right (accelerator) leg to a much less bent position, which was my main goal. Here's how I did it.
You need the following:
- One piece of approx 3x3 inches 10 gauge sheet metal
-One 5 inch long x 1 3/4 inch x 1 1/2 inch, 3 sided "2x4 reinforcing bracket" (Kind of a squareish U-shaped) (Found in the fencing section of Home Depot or similar hardware store) (See pic 4)
-Two 1 3/4 inch hose clamps
-Eight approx 1/2 inch long, 1/8 inch diameter nuts, and matching bolts
-Eight washers to match the bolts
-A drill with a 1/4 inch bit that will bore metal
-A hack saw
-Black spray paint
-A Sharpie or similar marker, something that will draw on the sheet metal
-About 4 inches of 2 sided foam tape
Old Oct 31, 2003 | 05:04 PM
Omicron's Avatar
Step 1: Remove the clutch pedal foot piece. It hooks to the pedal itself via a rubber flange that wraps around the edges of the pedal. I was able to flex the rubber flange around the edges and pop it right off.
Step 2: Put the sheet metal square up against the now-uncovered clutch pedal, and trace the outline of the pedal onto the sheet metal.
Step 3: Using a hack saw, follow the outline you just traced, and cut the sheet metal so that it is the same size and shape of the uncovered clutch petal. You have just made a replacement clutch pedal piece that the pedal will eventually snap onto just like it did the original clutch pedal.
NOTE: Be sure you make this backing the same size or slightly smaller than the "naked" clutch pedal, or you'll have a hell of a time getting the pedal to slip onto it.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext01.jpg
Old Oct 31, 2003 | 05:05 PM
Omicron's Avatar
Another pic
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext02.jpg
Omicron's Avatar
and another
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext03.jpg
Old Oct 31, 2003 | 05:09 PM
Omicron's Avatar
Step 4:
Cut the "2x4 reinforcing bracket" down into two, two inch long equal size pieces.Both will be about 1/2 shorter than the sheet metal you just cut in step 3.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext04.jpg
Omicron's Avatar
Step 5:
Fit the 2 pieces of the reinforcing bracket together like this:
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext05.jpg
Old Oct 31, 2003 | 05:10 PM
Omicron's Avatar
another pic
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext06.jpg
Old Oct 31, 2003 | 05:12 PM
Omicron's Avatar
Step 6:
Drill holes as needed in the sides of the reinforcing bracket pieces so you can bolt them together. I put 2 holes on each side.
Here you see the square, open-ended "box" you just assembled next to the clutch pedal piece. It looks like they are the same size in this pic, but the clutch pedal piece is actually longer and wider by about 1/2 inch.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext07.jpg
Old Oct 31, 2003 | 05:13 PM
Omicron's Avatar
Step 7:
Put the clutch pedal piece you've made on top of the "box" and drill 4 holes for mounting it to the box.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext08.jpg
Old Oct 31, 2003 | 05:15 PM
Omicron's Avatar
Step 8:
Using 2 washers per hole as stand-offs, mount the clutch pedal piece you've made on top of the "box." Now paint the entire thing black.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext09.jpg
Old Oct 31, 2003 | 05:16 PM
Omicron's Avatar
Step 9:
Snap the factory clutch pedal cover over the clutch pedal backing" piece you've made by gently prying the rubber "lip" back and popping it into place. when you're done, it will look like the pic below.
NOTE: If you made the backing piece too big in step 3, you may have to make it smaller before the pedal will fit over it. And this is a PITA to get on, regardless of how close the backing isto the right size. You may want to use some "303" (or similar) spray to give the pedal cover lips a good lubing, then hold the box in a vise and use a couple of small screwdrivers to pull the cover on.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext10.jpg
Old Oct 31, 2003 | 05:17 PM
Omicron's Avatar
another pic
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext11.jpg
Omicron's Avatar
and another
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext12.jpg
Old Oct 31, 2003 | 05:18 PM
Omicron's Avatar
Step 10:
Next, partially flatten out the hose clamps, open them, wrap them around the back of the "box" (opposite the pedal) and hook them back together.
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext13.jpg
Old Oct 31, 2003 | 05:20 PM
Omicron's Avatar
Step 11:
Now cut the two sided tape into two 2 inch strips and attach it to the actual clutch pedal
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext15.jpg
Old Oct 31, 2003 | 05:21 PM
Omicron's Avatar
Step 12:
Finally, put the new clutch extension in place, slip the hose clamps around the pedal from either side, and tighten the hose clamps. When you're done, it will look almost like this. This is shown with the hose clamps still loose for illustrative purposes. When you tighten them down you cannot see them at all. I also did a bit more touch up with the black spray paint (although I didn't take a pic, sorry) and the whole assembly is now virtually invisible!
Attached Thumbnails DIY: Clutch Pedal Extension-clutchext16.jpg
Old Oct 31, 2003 | 05:29 PM
oosik's Avatar
dude, that's nutz...........hows stability tho? any kind of movement? security?
I'm not sure whether to laugh or applaud!!
Old Oct 31, 2003 | 05:30 PM
Omicron's Avatar
Solid as a rock. I experimented with this quite a bit before I found something I was happy with.
Old Oct 31, 2003 | 06:06 PM
mikeb's Avatar
100% Italian
talk about DIY
great pics and job
Old Oct 31, 2003 | 06:28 PM
chinqlinq's Avatar
Originally posted by mikeb
talk about DIY
great pics and job
yeah seriously...looks good imo :D
Old Oct 31, 2003 | 06:41 PM
highspeed8's Avatar
Nice how-to. That gives me some good ideas.
Old Oct 31, 2003 | 06:58 PM
j1mb0x99's Avatar
Caution!
not bad... not bad at all... I hope no dumb *** tries to get really critical about the looks cause who the hell is gonna look under your clutch pedal?
-JiM
Old Oct 31, 2003 | 07:01 PM
neit_jnf's Avatar
Great job!
I'm a little disapointed to see that the RX-8 pedals are not true Aluminum pedals like the FD RX-7 had
Old Oct 31, 2003 | 08:49 PM
Len's Avatar
Len
I'm disappointed too. I hate that wrap-around rubber flange thing, and when I saw the faux-racing pedals I thought Good, they won't fall off like occasionally happened in my old Prelude.
Great DIY, Omicron.
Old Oct 31, 2003 | 10:54 PM
red_rx8_red_int's Avatar
Yes great job! I am average height but have short legs and share your complaint regarding the gas and clutch pedal placements. I think I will try your solution. Again, thanks for the great job detailing the mod.
