Last option for wheels, Enkei RPF1 in 17" or 18"?
Old Feb 2, 2008 | 04:05 AM
DOMINION's Avatar
I don't buy Kool-Aid
Question Last option for wheels, Enkei RPF1 in 17" or 18"?
OK guys this is my last wheel option and within my budget. Tell me what you think?
http://www.wheelsnext.com/wheels-tir...r%20Gloss.html
I'm thinking 17's with a off set? or 18's with a off set? I dont know yet cuz I dont know what off set to get in this kind of wheel.
So if I go with 17's or 18's what size with a off set can I get that will fit my 8 and that will fill my wheel gap (yes I'm getting springs )
2004 WB 6 speed.
Thanks for all the input!
-Gil
Old Feb 2, 2008 | 05:39 AM
Rotary__Rocket's Avatar
All Show All Go
whats the purpose of ur car
do you want to track it or just daily driving?
will you roll your fender by any chance?
Old Feb 2, 2008 | 06:22 AM
Wind Dance's Avatar
Central Valley RX8
Do it Dom Do it... Lovely wheels, light, strong, and track status. lol
I'd say 18" but then you'd get those who'd say 17"
Old Feb 2, 2008 | 06:23 AM
Wind Dance's Avatar
Central Valley RX8
http://www.enkei.com/RacingSeriesSpecs/RPF1.html
There offset and sizes.. options are your friend
18x8.5 +30 and 18x9.5 +38 sounds nice.. maybe someone with more input can help clear this up.
Old Feb 2, 2008 | 06:38 AM
All Show All Go
but i believe you need to roll you fender with this setup
Old Feb 2, 2008 | 06:39 AM
Wind Dance's Avatar
Central Valley RX8
I think so too.. but its not hard and would be lovely.
I rolled mine with a baseball bat, then coated the under with some coating spray.
Old Feb 2, 2008 | 06:46 AM
Spin9k's Avatar
Momentum Keeps Me Going
http://www.good-win-racing.com/Mazda...es/Wheels.html
If you have cut your springs, have lowered stiffer springs, or coilovers Enkei RP-F1 17x9 45mm offset and wow only 15lbs!!!!!!!!!!. What a sweet deal!! The big side benefit of 17s is you will maintain decent ride quality because your tires will be a bit higher aspect ratio. Rather than bouncy, bouncy, you'll be back to stock comfort levels, even on rough pavement. or any of the other 17s if you don't care so much about lowest weight.
If you are stock of course the 18x9 45mm offset 17lbs are the one. Or most any of the 18s are good again if you don't care about lowest weight.
Try to stay close to stock offsert of 50mm to keep the suspension working as designed. So 40-45 is what is best.
Last edited by Spin9k; Feb 2, 2008 at 06:50 AM. Reason: PS 17" tires are way cheaper than 18"s too!!!!
Old Feb 2, 2008 | 07:38 AM
Bastage's Avatar
DEVILMAN
2004 WB 6 speed.
-Gil
I'm getting the same wheels in 18X9.5 +45 with 265/35-R18 tires. There's a vendor on this forum that can give you a SWEEET deal on these wheels that makes the deal on the link you posted look like highway robbery.
Here's a link to the thread:
https://www.rx8club.com/auto-rnd-91/killer-special-enkei-rpf1-18x9-5-45-a-98939/
Send Endless Rotaries (aka Rishie) a PM with your zip and see what kind of deal he can give you.
Old Feb 2, 2008 | 08:20 AM
jones75254's Avatar
Hard to pass up 15 pound rims (the 17's) of the quality the rpf1's have. Some serious unsprung weight savings.
Old Feb 2, 2008 | 08:21 AM
spigot52's Avatar
How about these
http://www.good-win-racing.com/Mazda.../21-1051b.html
or the same with bling
http://www.good-win-racing.com/Mazda...t/60-0106.html
Old Feb 2, 2008 | 09:09 AM
huntingturtle's Avatar
psychoRN
I'm going with the Enkei RP-F1 18x9.5 c Toyo TIR 285/35/18 from Goodwin Racing. These will fit all 4 corners without rolling your fenders, unless u have lowered your 8. Price 2016. plus shipping-good company to deal with Brian is very knowledgable on 8's and Miata's -check him out regards Hank
Old Feb 2, 2008 | 11:29 AM
flip702's Avatar
Ho-hum
I'd go 18's... but looks good either way i think.
Old Feb 2, 2008 | 05:33 PM
SolarYellow510's Avatar
Definitely 17x9 +45et.
245/40-17 or 255/40-17 for track use, or 245/45-17 for street.
Old Feb 2, 2008 | 05:52 PM
DOMINION's Avatar
Smile
https://www.rx8club.com/showthread.php?t=98939
Thank you sir!
Old Feb 2, 2008 | 06:00 PM
Spin9k's Avatar
For track use, if you use the 15lb Enkeis, and get the 245/40/17 will get you like 4.8% acceleration improvement over stock, I think that even better than the '09's higher rear end dif, .6" lowering for better stability, and something like in the range of plus/minus 40lb total wheel/tire weight for greatly reduced unsprung weight over the stock 48lbs I think it is... plus tires are way cheaper... and the sidewall is even .1" reduced for added precision!
Talk about win-win-win-win-win!
Old Feb 2, 2008 | 06:27 PM
DOMINION's Avatar
^Dam a Spin you must track a lot lol I have three questions for you,
I had Tanabe GF210 springs on my old 8. Loved them.
If I get 17's will that make my speedo off?
Will they fill the wheel gap on my car? if you look at it from the side, the gap above the wheel and if you look at it from the back the way the wheels stick out?
Old Feb 2, 2008 | 07:26 PM
Spin9k's Avatar
These are 245/45/17 on 17"x9" wheels 45mm offset, car is lowered a bit w/coilovers ~20mm, so a bit bigger diam than we're talking but smaller than oem..
1) yes - unless someone's as-yet-avail flash unit allows the change in the ECU where the wheel diameter is. Hint, hint.
2) I think they do, but it's your opinion that counts. What do you think?
3) To me they look fine, but unfortunately I don't have any from the back. Here's one from the front though...
Old Feb 2, 2008 | 07:56 PM
DOMINION's Avatar
Thats sick! Something to think about for the track. But I think I'm going with 18's
Old Feb 2, 2008 | 09:46 PM
ivory8's Avatar
Vegas rx8!
dom i think these would look best on WB.
silver is just blah to me. it would be a sexy color combo for your car.
Old Feb 2, 2008 | 11:01 PM
A.Mair's Avatar
Gil you contacted Endless Rotaries off here for a price on these yeah?
Old Feb 2, 2008 | 11:52 PM
DOMINION's Avatar
Yez zer
Old Feb 4, 2008 | 06:51 PM
EricMeyer's Avatar
The Enkei 17 X 9 are exactly 15.4 lbs per wheel in silver. Scaled them today at the local PakMail store.
A 17 x 9 is perfect for a 225-245 tire. Plus you can lower the car just a smidge more. The handling on these cars is wonderful at a lower ride height (but not slammed). Consult your camber gauge and tire pyrometer for best results.
Old Feb 4, 2008 | 07:32 PM
Cody Red's Avatar
always filling [the c]up
18x9.5
Old Feb 5, 2008 | 05:26 AM
psychoRN
Sorry Rishie,I keep forgeting about you,being new to the forum I'll learn.So use to buying stuff for my 90 Miata from Goodwin the name just rolls off my tongue. Regards Hank
Old Feb 5, 2008 | 02:54 PM
Bastage's Avatar
DEVILMAN
did you order the Enkei's yet DOM?
