pulley question
Old Jan 29, 2008 | 06:35 PM
Rx8-13b's Avatar
pulley question
been looking at the angecy power pulley, from what i've seen on the forum, it seems to be the best bang for the buck. but was wondering, i haf 2 alpine amps and 2 nakamichi subs in the back, if i change to the agency power pulley, would i lose amps to run these accessories? how would i be able to check if it would be sufficient? thanks
Old Jan 29, 2008 | 07:25 PM
Revvittupp's Avatar
Two things.
1. If you underdrive the Alternator, you will lose current.
2, From all that I have read from SEARCHING on the forum, you would make your car faster by taking the stereo out then installing pullies.
Old Jan 29, 2008 | 11:20 PM
1stgen8's Avatar
Add a volt meter to your ride. I upgraded my stereo system and added a prosport volt meter. It reads about 14.2 when the bass hits. I have (2) amps, (7) tweeters, (2) 8" subs, (2) 6x9's and (1) 10" sub....you should be fine.
Old Jan 30, 2008 | 07:29 PM
987HYS's Avatar
Dragon Certified
Add a capacitor to your system and it should take care of the problem with an underdrive pulley
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
Wurromurro
Sep 20, 2015 05:02 PM
