high oil consumption
Old Oct 30, 2003 | 10:19 PM
roy's Avatar
roy
I'm new to rotary.
One question: Why does rotary engine consume so much oil? Can someone explain this in detail?
Thanks.
Old Oct 30, 2003 | 10:32 PM
sferrett's Avatar
Whaaaa?
"so much" is rather subjective, athough the fact that most other engines don't/shouldn't consume any makes the small amount the rotary does use "so much" more.
Anyhow - Oil is injected directly into the engine's combustion chambers to lubricate the seals inside the engine - specifically the apex seals which are on the 'corners' of the triangular-shaped rotors. Therefore oil is consumed as part of the normal running of the engine.
The reason why oil is injected in there to lube these seals is because there's no other way for oil to get to the seals, since they're inside the combustion chamber on the other side of the oil seals (comparable to the piston rings in a piston engine). Once the oil is injected it is subsequently burned and so the oil is "used" over time. The burning of the oil isn't the point of injecting it, lubricating the seals is the reason it's injected.
There are some good websites around explaining how the rotary works - check out http://www.rotaryengineillustrated.com/
Simon.
Old Oct 30, 2003 | 10:49 PM
RX-GR8's Avatar
as an example i just added 1/4 qt after the first 1100 miles. thats not that much oil.
Old Oct 31, 2003 | 04:59 PM
oosik's Avatar
sferret, excellant link thanks!
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
uZu
Dec 30, 2015 12:35 PM
talonhart2
Aug 26, 2015 04:14 PM
Nisaja
Aug 6, 2015 01:27 AM
vssystemluba
Jul 19, 2015 04:16 PM
