Fixing scratches
Old Jan 26, 2008 | 01:45 PM
shodan's Avatar
Fixing scratches
Hey guys anyone has any idea how to fix those?
Especialy that burned(?) mark under speaker...
Old Jan 26, 2008 | 02:50 PM
Icemark's Avatar
seat cover needs to be replaced
a vinyl repair shop can fix the door.
Vinyl paint probably can cover the center console, but otherwise it will take replacing.
Old Jan 26, 2008 | 04:35 PM
shodan's Avatar
yeah right. Replacing anything in car is not cheap...
I guess i have to come up with some home made stuff :P
Old Jan 26, 2008 | 05:23 PM
Oranje's Avatar
JM1FE
I wouldn't allow this guy to ride on the back console anymore if I were you
Old Jan 26, 2008 | 06:08 PM
staticlag's Avatar
The Professor
I tried having some scratches repaired at a vinyl repair place.
Doesn't work there is something about the surface that doesn't let their filler stick.
Most of the stuff in the interior needs to be replaced completely if it is damaged.
Old Jan 26, 2008 | 06:24 PM
shodan's Avatar
this car has tiny trunk... enough to fit spare tire and oil.. and thats basicly it.
Try to drive someone to airport with that car. Baggage ends up on the back seat
scratching plastic - Lesson learned, bc my car is yellow doesn't mean i'm a taxi.
Old Jan 26, 2008 | 08:09 PM
elysium19's Avatar
Something like that center console cover....should be relatively easy and cheap to find as a replacement. You definitely don't have to get a new one. Check out the forums for cars being parted out, or junkyards.
As sad as it is, there are plenty of 8's out there that get wrecked somehow, and often 80% of the parts are still good and are available for us to eat up if needed.
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
drlubell
Sep 26, 2015 11:58 PM
