Coolant Leak costs 1100 dollars at Oak Tree Mazda?!
Old Jan 25, 2008 | 03:44 PM
ZoominRex's Avatar
I notced my car had been leaking coolant so I brought it in and the estimate came out to be 1100 dollars for 3 hoses that connect to the radiator and coolant reservoir. Does it sound like a reasonable price or am I being had? I don't know of any local rotary mechanics and I am out of warranty. Any suggestions?
Old Jan 25, 2008 | 04:12 PM
ZoominRex's Avatar
ok so apparantly I need a new upper coolant hose, lower coolant hose, a coolant bottle bypass hose and a thermostat. All that with 6.6 hours of labor comes out to $1100+. Does that sound right to you guys?
Old Jan 25, 2008 | 04:14 PM
ZoominRex's Avatar
I found the parts on Finishline for about 80 bucks so it looks like they want 1000 for labor.
Old Jan 25, 2008 | 04:35 PM
Charles R. Hill's Avatar
Owner of BHR
What does their labor/hour cost?
For what they are charging you, I'd fly there to CA and do the job for you.
Old Jan 25, 2008 | 04:40 PM
sauceyI986's Avatar
i had an issue like that happend to me last year my car was leaking coolant bad. i got mine under warrenty but $1100 is too much i think personally.
Old Jan 25, 2008 | 04:42 PM
ZoominRex's Avatar
135 an hour. its kind of outrageous
Old Jan 25, 2008 | 04:43 PM
ZoominRex's Avatar
my warranty just expired a few months ago
Old Jan 25, 2008 | 04:50 PM
ZoominRex's Avatar
jeez the car is only worth maybe 15K and shelling out 1100 dollars for this repair is hard to stomach.
Old Jan 25, 2008 | 04:53 PM
agoodcave's Avatar
6.6 hrs????? That's crazy. The reservior hose should take 2 min. Upper/lower radiator maybe 1hr. Why the thermostat? Is that where the leak is? Are you running warm?
Mike
Old Jan 25, 2008 | 04:59 PM
expo1's Avatar
He's as bad as Can
Gee I got a whole engine installed for $1,000 along with new belts, hoses, themo, mounts, & starter. But that wasn't a dealer. But the guy did say getting those hoses of was a pain. If your out of warranty like myself you should stay away from the dealership.
Old Jan 25, 2008 | 05:04 PM
LionZoo's Avatar
road warrior
I'll do it for $400!
Seriously, that's an insane price. Check with the local board, there are a couple rotary shops up in the Bay Area. Much better to take it to them, it's probably higher quality work too.
Old Jan 25, 2008 | 05:06 PM
ZoominRex's Avatar
yah sounds like I need a second opinion. I don't know of any local rotary mechanics though. I guess I'll need to ask around.
Old Jan 25, 2008 | 05:08 PM
Owner of BHR
The intake and battery trays need to be removed to most easily get to that stuff but, once they are, it's a cinch.
Old Jan 25, 2008 | 05:12 PM
DarkBrew's Avatar
Extraordinary Engineering
Dealerships! Find a good shop and buy the parts on-line
Old Jan 25, 2008 | 05:43 PM
laythor's Avatar
I zoom therefore I am.
i've got to think any radiator place could do it for a 1/10th of that price
Old Jan 25, 2008 | 06:14 PM
Nubo's Avatar
Lubricious
Yeah, maybe I'm missing something but it doesn't sound rotary-specific.
Old Jan 25, 2008 | 06:59 PM
Socket7's Avatar
ಠ_ಠ
A coworker clued me in about a Bay area rotary shop in Santa Clara called Rotorsport. I can't say that I've ever had any dealings with them, but I bet they can beat the price the stealership gave you. If nothing else, it's a place for a second opinion.
http://www.rotorsport2.com/
Old Jan 25, 2008 | 07:59 PM
ZoominRex's Avatar
thansk guys I think I'll take her to rotorsport. Thanks for the link Socket7. Worse comes to worse I'll end up at the dealership again anyways.
Old Jan 26, 2008 | 12:26 AM
The hose are freaking cheap. 1100 bucks ? wow
135 bux per hour is already nutz. 1100 bucks for 1 hour job + not even 100 bux for parts. Wow. They just won the Rip off of the year awards !
I did my own Radiator install and replace my own hose with *better* silicone ones. That was my first time and it took me maybe 4 hours to do it, yeah I know. but I got stuck at 2 parts, First one was, I was thinking of *saving my stock Rad just in case*, so I tried to pull the rubber hose out of the upper outlet. Well, it was stuck like nutz. and after about 1/2 hour of trying to pull it out, the plastic outlet cant handle it and decided to just break off. Yep, my old rad is gone. the crazy thing is, the hose still perfect, not even a single crack.
Second hard part was, to PUT the Silicone hose back into the correct location. Good thing about Silicone hose is that they dont *flex* like rubber. Heat or cold. Thats a great thing to have for cooling systems.
but the bad thing is, cuz its *not* flexible, and the sizing was just right, it was a nightmare to try to put it back together.
if u ask me to do everything again now Im pretty sure I can do it within an hour or 2 if I take my time. I know all the tricks from the *painful 1st timer experience*.
but think of this, those dudes Working @ dealership doing these kind of **** all day long. It will never take them 6+ hours to do it.
and thermostat ? pst, that thing cost like what 25 bux ? and it takes no longer than 15 minutes to replace it if you know where to look. wow
So, stay away from that dealership, run as fast as you can. and go do it at rotosport.
Old Jan 26, 2008 | 01:38 AM
kersh4w's Avatar
Hit & Run Magnet
i saw "coolant leak at oak tree."
i pictured something.
Old Jan 26, 2008 | 11:28 PM
ZoominRex's Avatar
picked the car back up from the stealership and taking it to Rotorsport on Monday. Maybe with the cash I save I'll treat myself to some extra work.
Old Jan 27, 2008 | 03:16 AM
NewtonPulsifer's Avatar
Paul at Rotorsport in Santa Clara is great and Mike at Mr. Mazda in Campbell is awesome as well. Ivan Kojnok who works on people's cars in Sunnyvale on weekends is good - he's at 408-730-0567
Old Jan 27, 2008 | 04:55 AM
Benjamz's Avatar
Tony says, RX8s are GREAT
do not go back to the stealership ever!!!!!!!!!! you have no more warrenty, that means no more dealership.. period!!!!! we have tooooo many rotary specislist in the bay area to take your car to.
hell if you have a garage, ill do the labor for free... im working on a project and i could benifit from this... replacing hoses and a thermostat is cake
ive got tools, if you have a garage.. no labor charge.. you just buy parts and you get experience too..
but you gotta wait until i get back to the bay area in mid feb..
plus i got a hook up on dyno so we can get a base line when your car is all better
yes free labor.. i dont own my business yet, i have no right to charge
pm me... ben
Last edited by Benjamz; Jan 27, 2008 at 02:16 PM. Reason: fix spelling, im bad at it
Old Jan 27, 2008 | 05:06 AM
Benjamz's Avatar
ok here.. listen to me..
buy the mazsport modified water pump.. 250
buy ebay or other silicon hoses upper and lower 70
well go to pepboys and get silicon hoses that go to the reservior 25 or less
thermostat and gasket 25
radiator fluid 10
thats all you need to spend.. i just recommend the water pump because your redoing your cooling system anyways.. you dont need an upgraded radiator
if you cant wait... good luck with everything.. cheers
Old Jan 27, 2008 | 12:38 PM
Yes, if you are down there... fix it permantly.
A new upgrade water pump and hoses would be good advice if plan on keeping it long and driving it another 75k or more miles.
