'Lapping' noise?
Old Jan 23, 2008 | 10:14 AM
w0rm's Avatar
PUSHER ROBOT
'Lapping' noise?
I've been having a hard time tracking down what can only be described as a lapping noise coming from the engine bay under idle. It seems like it would be most likely a belt but I've checked and tension seems fine and no damage to any belts.
Anyone have any ideas? I can't hear the lapping under load but that might just be due to the exhaust note. My MPG has also dropped considerably. I'm used to having a CEL due to a straight pipe, but I'll be getting the codes pulled to see if there's anything else.
In addition, I also have a very high pitched whine coming from the engine bay 80% of the time, mostly during cold start / warmup period. Its probably an electric motor or the alternator.. Anything I should check in to on that?
Old Jan 23, 2008 | 11:38 PM
High pitch whine is normal.
Lapping. What does lapping sound like.
You mean when I take my tonque and like something like a dog?
Old Jan 31, 2008 | 12:08 AM
DOMINION's Avatar
I don't buy Kool-Aid
"Lapping noise"? Sounds like a Rotary to me
Old Dec 7, 2008 | 07:41 PM
Detrich's Avatar
幹他媽!
mine just starting doing this noise too... it's not the whistle noise of the rotary... it's some other type of swooshing sound that pulsates:
"shhh shhh shhh shhh" sounding like that...
it happens intermittently on my car- even when it's warm. i'm not sure what it is either and wonder if anyone knows what this is or if it's something i need to worry about.
any ideas?
Old Dec 7, 2008 | 08:18 PM
restiller's Avatar
sofa king
I was wondering if that sound was my fans. Noticed it around 40k miles. Couldn't be temp related because I heard it at 60 degrees F; it's 20F now and I still hear it.
Subscribing for answers.
Old Dec 7, 2008 | 09:08 PM
Detrich's Avatar
幹他媽!
no one has any experience with this issue?
Old Dec 8, 2008 | 03:21 PM
lshu's Avatar
Driving makes me :)
It probably is a good idea to check your plug wire connections. I had a kind of loud "ch ch ch" sound a while ago, and I found that the plug wire boots were not firmly on the spark plugs. Pushed everything in firmly and it was fine.
Old Dec 8, 2008 | 08:26 PM
Detrich's Avatar
幹他媽!
thanks for the feedback... are the wire plugs hard to reach for the mechanically-challenged?
Old Dec 8, 2008 | 09:00 PM
05rex8's Avatar
sold the 8... :(
maybe you are hearing a fapping noise instead
Old Dec 9, 2008 | 12:04 AM
Potentiated's Avatar
The lapping also sounds like leaves rustling. It happens when you first start your car and, while the car is stationary and in neutral, gently press the accelerator and then let it idle. The lapping/rustling leaves could actually be water swishing.
Could it be the water pump?
Old Dec 9, 2008 | 09:13 AM
restiller's Avatar
sofa king
^^Yes, that describes the sound perfectly!
Old Dec 9, 2008 | 11:18 AM
Detrich's Avatar
幹他媽!
seriously guys, we are asking about & trying to discuss a legitimate problem & get help from other club members with knowledge on our issue... If u really don't have constructive info to contribute then please kindly save your comments for the lounge or other threads....
Thanks & much appreciated...
Old Dec 9, 2008 | 11:25 AM
air in the heater core. car needs burped. seriously
Old Dec 9, 2008 | 11:27 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Yeap I get the noise of liquid moving around when i start my car. I'm also parked on my driveway, which is on a 10-15 grade incline.
Old Dec 9, 2008 | 11:28 AM
And the heater core somehow makes a rustling leaves sound? Are you sure? Seriously.
I think it's more of a water jiggling/swishing sound. To get the sound, gently press the accelerator, and you will see that the sound is concomitant with accelerator. In this case, could it be the water pump moving water around?
Old Dec 9, 2008 | 11:38 AM
i dont have a lapping sound. but from the description,
trying to diagnose over the internet, without being in the car thats what id say. if they are all coming from the right side.
but i also believed there is good probability that you "Potentiated" , Detrich and worm are each talking about something different
Old Dec 9, 2008 | 11:46 AM
Detrich's Avatar
幹他媽!
Hmm... Well mine for sure doesn't sound like fluid or liquid motion... The sound I'm getting matches what the thread author described, which is y I sounded in, as I'm trying to decide whether this issue requires a visit to the dealer or if it's something else... Again it kinds sounds like something rubbing gently against a conveyer belt & pulsating during engine idle like "shh... shhh...shhh.". It's not super loud but just enough where it's noticeable.
Thanks for sounding in.. Keep the comments going. Hopefully someone will know exactly what this is...
Old Dec 9, 2008 | 11:49 AM
drive up here so i can hear it
Old Dec 9, 2008 | 12:09 PM
Detrich's Avatar
幹他媽!
Too bad it only started recently or I couldve let u listen @ sevenstock
Old Feb 23, 2009 | 04:46 AM
Detrich's Avatar
幹他媽!
i'm going to make an app't and get this checked out as soon as the rain stops. hopefully this week or next. will let everyone know what i find out...
Old Feb 23, 2009 | 05:29 PM
Detrich's Avatar
幹他媽!
alrighty... i made an app't to have this looked at this wednesday. will post what i find out afterwards- though it doesn't seem like too many ppl really are following this thread anymore
Old Feb 23, 2009 | 06:20 PM
Charles R. Hill's Avatar
Owner of BHR
If it is a "whistle", check your three breather hoses with the plastic elbows connected to the intake flex duct. Those are prone to becoming brittle/cracking and the "whistling" may be the oil injection nozzle breather hose. Based on limited information I would guess this to be the problem as you have poor fuel economy as a seeming related symptom.
Leaks in these hoses cause erratic MAF sensor readings and the PCM doesn't "like" it.
Old Feb 23, 2009 | 09:55 PM
DOMINION's Avatar
To the og poster; search: "ticking" on this site and you might find your issue.
Old Feb 23, 2009 | 10:29 PM
risky business's Avatar
IRC Founder
that was my first thought when i read the title!
Old Feb 23, 2009 | 10:32 PM
05rex8's Avatar
sold the 8... :(
Yeah, Detrich didn't appreciate my sense of humor:
