Help! any ideas?
Old Jan 21, 2008 | 03:53 PM
DLASH15's Avatar
Im a greenhorn
Help! any ideas?
Situation: going from 1st to 2nd gears. Once shifted to 2nd there were no gears. The car does not accellerate in any gears. Basically like stuck in neutral. The TCS/DCS light and ABS light are on. ANY IDEAS?
Old Jan 21, 2008 | 04:06 PM
DarkBrew's Avatar
Extraordinary Engineering
Do you still have warranty? How many miles? What year?
What have you been working on? Do you have maintenance records?
My Guesses so far
Did you disconnect the battery?
You can reset the TCS/DCS light and ABS light by steering full left then full right.
As for you other issue, check your shifter (see the AFE short shifter install DIY to see how to remove the old one). If that's okay then check your clutch pedal bracket for cracked spot welds.
Or see your dealer.
Old Jan 21, 2008 | 04:10 PM
chancejat's Avatar
Drive it like u stole it!
did you abuse 1st gear at all just before your problem started......by abuse i mean wheel hop, or high rpm clutch drop, etc....
92trbolzr
May 18, 2025 09:04 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
