Movement in the rear / feels unstable???
Old Jan 16, 2008 | 03:43 PM
Vasichko's Avatar
Ok so here is what's going on.
My motor mounts are good, I have the latest bracket/mounts.
My car was in a month ago to get the throw out bearing warrantied.
Ever since then the car feels sloppy in the rear, it feels like something is moving or bouncing even when driving normally.
I have checked for blown shocks, no issues there.
The dealer says everything is fine and the car is supposed to be like this.
I did some spirited driving to see how it felt and I dont wanna even go above the speed limit at this point, the car doesnt feel as solid as it used to.
Also, I dont know if it is bad luck or what, but the new throw out bearing is going again and this time they are telling me its normal and it is gear over turn noises. Didnt know trannys wear supposed to squeak in neutral but stop when I depress the clutch. LOL.
What could it be guys?
Old Jan 16, 2008 | 04:05 PM
does the clutch chatter at all?
you might have them check the ppf for tightness and alignment... also this is simple, but tire pressure?
how many miles on the car?
Old Jan 16, 2008 | 04:07 PM
Vasichko's Avatar
28k miles. Tire pressure is 32psi all around cold.
How difficult would it be to alight the ppf by myself and align it?
Old Jan 16, 2008 | 04:10 PM
you have a service manual.? it is not hard, you will likely need an impact wrench..
Old Jan 16, 2008 | 04:12 PM
Vasichko's Avatar
Attempting to download right now.
The clutch does chatter yes, but I know its not clutch chatter. Its more of I high pitched squeak.
Old Jan 17, 2008 | 09:34 AM
VOODOO8's Avatar
Hermitage Holdout
"Didnt know trannys wear supposed to squeak in neutral but stop when I depress the clutch. LOL."
FYI - My first bearing replacement exhibited the same noise after it was replaced. Quieted down after about 1000 miles and has been fine for 28000 miles since then.
RevMeHarder
Jun 1, 2026 02:30 PM
Paul_Y
Sep 21, 2015 02:23 PM
stickmantijuana
Sep 4, 2015 10:31 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
