BeatRush parts from GummyGrip
Old Dec 31, 2007 | 09:12 PM
marsredr100's Avatar
I just ordered the following BeatRush parts from GummyGrip http://www.gummygrip.com in Las Vegas, Nevada 702-457-7278
BeatRush Center Transmission Bracing
BeatRush Rear Differential Support Brackets
BeatRush Aluminum Under Panel
I talked to Matt the owner of GummyGrip and he was more than helpful with my order. Matt shipped and email me the shipping tracking number the very next day. Great customer service I might add is a big plus in the automobile business.
My BeatRush parts are do next week and I will be posting pictures of the parts, installation pictures, weight of parts and overall handling experience/improvements.
Also, next month I will be ordering the BeatRush Rear Arm Performance Bracing
Stay tuned and zoom-zoom
Old Jan 2, 2008 | 07:34 PM
guidosrx8's Avatar
PIT STOP!
just checked out the site... looks like they have some good stuff! be sure to let us know how it works out!
Old Jan 2, 2008 | 08:48 PM
c41250n's Avatar
nice, i love beatrush stuff.
too bad i already got autoexe underbraces.
Old Jan 2, 2008 | 10:00 PM
staticlag's Avatar
The Professor
http://www.rx8web.com/forum/showthread.php?t=7054
Old Jan 2, 2008 | 10:30 PM
NgoRX8's Avatar
Bling! lol
i like their front strut bar over most 2 point strut bars.
Old Jan 3, 2008 | 12:40 PM
altspace's Avatar
Eccentric Shafting
Very nice! I have the front strut bar.
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/beatrush-front-strut-bar-127622/
Old Jan 9, 2008 | 07:04 PM
UPS delivered my BeatRush parts that I ordered from GummyGrip http://www.gummygrip.com/ in Las Vegas, Nevada 702-457-7278
See attached pictures.
Attached Thumbnails BeatRush parts from GummyGrip-picture-212.jpg   BeatRush parts from GummyGrip-picture-211.jpg   BeatRush parts from GummyGrip-picture-205.jpg
Old Jan 9, 2008 | 07:22 PM
I took the time to weight of each BeatRush component set that I received. See below total weight for those of you that are concern about adding/reducing weight on your RX8.
BeatRush Center Transmission Bracing………5 pounds
BeatRush Aluminum Under Panel…………….4 pounds
BeatRush Rear Differential Support Brackets...3 pounds
The Center Transmission Bracing and Rear Differential Support Brackets are made of steel with two urethane bushings each.
The installation instructions are written in Japanese but it includes detail illustrations that are easy to follow. See attached.
Attached Thumbnails BeatRush parts from GummyGrip-picture-216.jpg   BeatRush parts from GummyGrip-picture-213.jpg   BeatRush parts from GummyGrip-picture-206.jpg
Old Jan 9, 2008 | 07:31 PM
Installation time of all BeatRush parts that I ordered from GummyGrip http://www.gummygrip.com in Las Vegas, Nevada 702-457-7278 took a total 2.5 hours. That included the time it took me to drive the car in the garage, up on four jack stands, print Mazda instructions on removing/installing power plant frame installation (needed for reset power plant frame and tightening torque) and set car back on the ground all by myself.
See pixs of the BeatRush Aluminum Under Panel.
Attached Thumbnails BeatRush parts from GummyGrip-picture-217.jpg   BeatRush parts from GummyGrip-picture-218.jpg   BeatRush parts from GummyGrip-picture-219.jpg   BeatRush parts from GummyGrip-picture-221.jpg
Old Jan 9, 2008 | 07:33 PM
See pixs of the BeatRush Center Transmission Bracing.
Attached Thumbnails BeatRush parts from GummyGrip-picture-222.jpg   BeatRush parts from GummyGrip-picture-223.jpg   BeatRush parts from GummyGrip-picture-224.jpg   BeatRush parts from GummyGrip-picture-225.jpg   BeatRush parts from GummyGrip-picture-226.jpg
Old Jan 9, 2008 | 07:37 PM
See pixs of the BeatRush Rear Differential Support Brackets.
Attached Thumbnails BeatRush parts from GummyGrip-picture-228.jpg   BeatRush parts from GummyGrip-picture-229.jpg   BeatRush parts from GummyGrip-picture-230.jpg   BeatRush parts from GummyGrip-picture-231.jpg
Old Jan 9, 2008 | 07:53 PM
You will have to support the transmission before removing the power plant nuts, install the BeatRush Center Transmission Bracing, re-adjust the power plant frame and torque down the transmission to power plant bolts. Once you are done installing the BeatRush Center Transmission Bracing you can move to install the BeatRush Rear Differential Support Brackets. Support the front of the differential and loosen the top two differential to power plant nuts. Install the BeatRush Rear Differential Support Brackets and torque down the two differential to power plant nuts.
Attached Thumbnails BeatRush parts from GummyGrip-lastscan1.jpg   BeatRush parts from GummyGrip-lastscan2.jpg   BeatRush parts from GummyGrip-lastscan3.jpg
Old Jan 9, 2008 | 08:16 PM
I drove my RX8 for a few miles and everything checked out OK. I will be driving the car tomorrow to work and to a Mazda dealer for a warranty part exchange (about 200 miles of street and interstate road trip) and will let you know of any street driving difference. I’m doing an AutoX next month and hopefully I will also have installed the BeatRush Rear Arm Performance Bracing that I’m ordering next month for a full evaluation of the BeatRush kit.
Many thanks to Matt from GummyGrip http://www.gummygrip.com in Las Vegas, Nevada 702-457-7278 and I will keep you posted for further developments.
Old Jan 9, 2008 | 08:58 PM
Nice!! So you bought all of this for Auto X?
Old Jan 9, 2008 | 09:21 PM
In part for AutoX and also because I used to own a highly modified 2nd gen GTU and I got used to the stiff but highly responsive suspension ride.
Old Jan 10, 2008 | 12:06 AM
eviltwinkie's Avatar
So if I get this right...the underpanel covers the oil pan? If so...would a greddy one cause any issues? I was under the impression that the greddy pan extended down a little bit...
Old Jan 10, 2008 | 05:56 AM
Yes, it does. I'm changing my oil today or tomorrow and will be posting pixs and clearance distance from OEM oil pan to BeatRush Aluminum Under Panel.
Oil change done and here are the pixs. The distance between the bottom of the OEM oil pan and the BeatRush Aluminum Under Panel is 20mm/2cm or approximately 25/32 inch.
Attached Thumbnails BeatRush parts from GummyGrip-picture-232.jpg   BeatRush parts from GummyGrip-picture-233.jpg   BeatRush parts from GummyGrip-picture-234.jpg   BeatRush parts from GummyGrip-picture-235.jpg
Old Jan 10, 2008 | 06:20 AM
altspace's Avatar
Eccentric Shafting
One more time....GummyGrip in Las Vegas, Nevada 702-457-7278
Or you can purchase BeatRush parts from www.mazdarx8online.com Ask for Ken.
Old Jan 11, 2008 | 09:10 PM
After 150+ miles and happy to report that my car handling has improved significantly. Road handling/feedback is better and with minimum sacrifice in comfort. To the point that I had to order better brake pads/rotors and need to pay more attention to the speedometer. No squeaks, vibrations, rattling, etc. Can’t wait until my next AutoX in February and I will keep you posted.
Old Jan 11, 2008 | 10:15 PM
nuke0907's Avatar
Never Blend In
does the aluminum under panel replace a plastic under panel? does the tranny brace work with an auto?
Old Jan 11, 2008 | 10:28 PM
BigRed's Avatar
w8nkel
auto...hehehehe
j/k. well, kind of
Old Jan 11, 2008 | 10:31 PM
Gecko69's Avatar
the parts look nice......kinda off topic, but am I the only one who noticed what the car was lifted on???? poles and wood blocks???? I would be a little worried being under the car...but maybe the picture is decieving??
Old Jan 12, 2008 | 04:12 AM
Negative. The black part is the top of metal jack stands and the wood pieces are to distribute the weight/avoid damaging the car. Also, (not shown) two 4 1/2 tons (shop quality) alligator type jacks. Overall, four jack stands and two floor jacks holding the car of the ground.
Just to set the record strait.
Old Jan 12, 2008 | 10:22 AM
The aluminum under panel does NOT replace the front plastic under panel. The aluminum under panel fits/covers the open area directly under the oil pan area. The panel is held in place with four bolts and it needs to be removed in order to access the drain plug. However it only adds an additional 5 minutes at the most to the oil changing process.
According to the Mazda parts manual the part number for the Power Plant Frame and the Cross Member are both the same for the manual and automatic transmission RX8. I'm 99.99% sure that it will fit an auto RX8 since the Transmission Brace is bolted down between the existing cross member bolts and the two lower front power plant bolts.
I can post the auto transmission power plant intallation instructions if interested.
Old Jan 14, 2008 | 11:38 PM
Bradleydrivn's Avatar
As for the Aluminum Under Panel:
Before I decided on an RX-8 I was looking around the 350z and the s2000 forums and I picked up somewhere that you are never supposed to mess with the air directly under your engine.
Putting a diffusing like part under your engine bay acts as a cap to retaining hot air and whatever else it needs to do. Can anyone verify this or refute? It would be good to know.
