DIY Rotor Rear Fog light in the making
Old Oct 25, 2003 | 11:29 PM
seikx8's Avatar
Is this title ok?
Lightbulb DIY Rotor Rear Fog light in the making
Here is a picture of the half done fog light test fitting. Still brainstorming about the type of LEDs or bulbs to use. It's best of both world: It's cheap DIY while getting what I like :D
https://www.rx8club.com/attachment.p...tid=5951&stc=1
Old Oct 26, 2003 | 03:19 AM
HMMM very interesting...have to see the pic with it on at night..
Old Oct 26, 2003 | 09:24 AM
Need For Speed's Avatar
SPEED-8
yes veri intrestin i thinc to you have to post sam more photo on nigt
Old Oct 26, 2003 | 10:45 AM
seikx8's Avatar
Is this title ok?
Now to think of it, still debating about wheter to mount with three srews to expose the corner or put three LEDs for hilight and mount it using hidden screws inside. Anyway, I will post my final result, now only if I can find a dual bulb holder
Old Oct 26, 2003 | 12:15 PM
mikeb's Avatar
100% Italian
nice work
Old Oct 26, 2003 | 06:27 PM
Omicron's Avatar
Yes, please post more info, and/or step-by-step directions! I am *very* interested!!! Also, how did you wire this in???
Thanks...
Old Oct 26, 2003 | 10:16 PM
Irish_in_a_RX8's Avatar
Very creative! What does the original rear fog lights look like? Anyone have a pic?
Old Oct 27, 2003 | 03:55 AM
SPEED-8
nice work irish_in_a_rx8 with your brakes, good idear
Old Oct 27, 2003 | 10:08 AM
Omicron's Avatar
The rear fog light for Euro spec models looks like this:
https://www.rx8club.com/attachment.p...tid=5981&stc=1
Old Oct 28, 2003 | 09:52 AM
Nice....
Old Oct 28, 2003 | 01:13 PM
SPEED-8
nice the red brake caliper with rx8 in with.
Old Nov 18, 2003 | 08:58 PM
my10ae's Avatar
Moderator
Any updates on this mod???
Old Nov 19, 2003 | 01:42 AM
seikx8's Avatar
Is this title ok?
Almost just have to install the darn thing. Was so busy these days! And will be taking a vacation next month. Hopefully, I will have time to take pic of the install this weekend.
Old Nov 19, 2003 | 09:29 AM
huhsler's Avatar
Any legality issues with the rear fog light in the U.S. ?
I saw some unresolved threads on this question.
Old Nov 19, 2003 | 09:54 AM
my10ae's Avatar
Moderator
Thanks for the update seikx8
Old Nov 19, 2003 | 01:41 PM
Thanks, I missed your post...I actually went for the black look with RX8 on top. My avatar was a friends I did.
It will be nice to see the final version - i heard that the application of the rear fog light was quite complicated
Old Nov 21, 2003 | 12:53 AM
takahashi's Avatar
As it is not an option for Australian model I have the light ship from Japan (Mazda JDM)
I have mine install by the mazda dealer today. It works wodnerfully. Have the DSC button changed to a dual fog light/DSC off (each occupy one half). The wiring is pain. They have to strip off the steering coloum casing the dash board. The front panel (driver side) wire the thing thru the driver side door. thru the boot and have the rear bumper off to wire and cut.
Fortunately if have factory made ALL bumper have bolt sets that ready for fitting (no drill required) ~ Well except the cutting of the rear triangle
Tori
Old Nov 21, 2003 | 06:09 PM
Omicron's Avatar
Takahashi -
Can you tell me please where exactly they cut the rear triangle? I got the same JDM light yesterday, and went to install it today. Problem is, it looks for all the world like the foglight is too big to fit through the triangle!
I wasn't brave enough to start cutting until I posed the question on this forum... where exactly do you cut? The inner edge (around the diameter) of the triangle?
Finally, can you please post a close up pic of the fog light? All the pics I've seen so far have been from like 15 feet away. I need a close up to see how far into the cutout the light sits.
Old Nov 21, 2003 | 06:49 PM
takahashi's Avatar
Did you have the instruction book to come with the lights?
I saw in the instruction book (not with me - still in Mazda dealer - I was going to pick that up Monday). It said that you cut the most inner bit of the triangle from the inside - hence you have to take the bumper off. You still need the inner side of the triangle for supporting the fog light.
If you want the installation booklet I can scan it on Monday or email you a photocopy if you like.
Old Nov 21, 2003 | 07:06 PM
Omicron's Avatar
Man, that's be AWESOME!!! I believe you still have my email address, no?
Old Nov 21, 2003 | 07:10 PM
takahashi's Avatar
Yes I have your email...
I think you need a Japanese - English translator as it is in Japanese. Anyhow - the pictures say 1000 words in the booklet and even the Mazda mechanics can read (no offense).
AND yes I think $A200 for labour is kinda cheap (I AM F'ing HAPPY)
Still waiting your 6 stacker right... not too long I suppose.
Old Nov 21, 2003 | 07:56 PM
mikeb's Avatar
100% Italian
so its 200 for mazda to install
Old Nov 21, 2003 | 08:01 PM
Omicron's Avatar
Not to worry Steve, I'll figure it out.
Mike, that's $200 Australian.
Old Nov 21, 2003 | 08:04 PM
mikeb's Avatar
100% Italian
ok so how much US for install and fog light?
did you get it from canzoomer
Old Nov 22, 2003 | 12:04 PM
Omicron's Avatar
Yep. The light itself was like $88, as I recall, and comes with nothing but the light. No idea what a dealer would charge to install it, but most likely a coupla hours of labor.
Depending on how you wanted to wire it, you might also need to get the Mazda factory switch, which is about $35 from CanZoomer. Or you could use your own, if you're comfortable tapping into power from somewhere, then running it to the switch/light. I got the factory switch, but may not use it. Initially I plan to tap the rear fog into by rear brake lights, so I have a "low mount" brake light. Think that'll be kinda unique, and will save me a lot of wiring effort. If it's too bright for that, I'll try to get a lower wattage bulb. And if that still doesn't work out, I'll wire it to a dash switch. We'll see.
Problem is, it didn't come with any instructions, and I wasn't willing to go cutting on my rear bumper "underskirt" till I knew for sure it'd fit. Takahashi is going to send me some close up pics of the install, and email me the installation manual. It's in Japanese, but I think I'll be able to figure it out from the diagrams.
I'll keep you all posted.
