Rough Idle... solutions?
Old Dec 26, 2007 | 02:05 PM
T-rev429's Avatar
T-rev
i just gor my car out of the body shop. they replace my front bumper along with some reinforcement parts and put in a new AEM CAI. since i got it back i have had a rough idle. when stopped at stoplights my car drops down to 1rpm and then drops further to 3/4 of an rpm where it feels like my car is going to stall. what can i do to repair this problem. it was in the shop recently and the ignition coild were replaced due to a misfire in cylinder 2 obd readout. could my spark plugs have gone bad? or did they not install my intake right? can anyone help me diagnose the problem....
Thanks,
Trevor
Old Dec 26, 2007 | 02:49 PM
Coop '04's Avatar
DELIVERED 07-17-2004
3/4 of an RPM is quite slow, no wonder it is vibrating...
Old Dec 26, 2007 | 04:24 PM
is it doing this?
https://www.rx8club.com/series-i-trouble-shooting-95/very-rough-idle-video-attached-118728/
Old Dec 26, 2007 | 05:54 PM
T-rev429's Avatar
T-rev
that is what its doing... any suggestions on wha i might do to fix it?
Old Dec 26, 2007 | 05:58 PM
bad neutral switch. Dealership shoudl fix it if you're under warranty.
There's a few threads around here for it as well. I'd link them for you but I'm heading out of the office right now for an appointment.
Old Dec 26, 2007 | 06:26 PM
T-rev429's Avatar
T-rev
can you link they to me tomorrow... thanks!
Old Dec 27, 2007 | 12:48 AM
Re-set your ECU
Old Dec 27, 2007 | 08:17 AM
no need to link or anything
just bring it into dealership, tell them the netural switch is broken causing it to idle super funny. they will fix it.
Old Dec 27, 2007 | 12:09 PM
It's common for body shops to disconect the battery before working on it.
Just re-set the ECU to make sure and drive it a few cycles.
Anytime you re-set or disconnect you will have idle problems until the car goes through a few cycles and the computer learns how to manage the car.
Old Dec 27, 2007 | 12:27 PM
T-rev429's Avatar
T-rev
Will my extended limited powertrain warranty cover getting the neutral switch replaced? my regular warranty is already used up. i also have an AEM CAI and greddy strut bar... will they give me problems about my warranty if i have those on there?
Old Dec 27, 2007 | 12:30 PM
T-rev429's Avatar
T-rev
what exactly is going on.... is it the neutral switch or the car trying to learn how to drive itself after the battery was disconected? i drove the car through 4 gas tank cycles ant still had a rough idle. it was fine when it went into the body shop.
Old Dec 27, 2007 | 12:46 PM
what exactly did the body shop do?
If you've gone through 4 entire tanks of gas it is most likely not the car relearning. (unfortunately)
Take it into the dealership and they can fix it rather quickly
Old Dec 27, 2007 | 12:58 PM
T-rev429's Avatar
T-rev
the body shop replaced the front end of the bumper along with all the grille and reinforcements, the cold air intake and lights and fenders. do you think they installed the CAI wrong?
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
Evan Gray
Sep 26, 2015 12:30 PM
