Rev limiter at lower RPMs
Old Oct 24, 2003 | 03:12 PM
Jasper_the_2nd's Avatar
I'd read about the variable rev limiters in other cars, but I didn't think the 8 actually did that, until today.
Hopped in the car after work (a balmy 5 degrees), a didn't give it very long to warm up, since I was in a hurry. I didn't have to wait the normal minute and a half to pull out of the driveway. The on ramp to the highway is right across from the driveway at work, so normally I just pull out and go straight onto the on ramp.
I got about half way across the road, and the car hit the rev limiter, at 6500 rpm. Not expecting it, it bounced a few times before I even realized what was going on.
Once I got up on the highway I dropped down to third to see if it was still doiing it, but it was back to normal by then.
Is this something normal, and I've just managed to never get out of work that quickly, or what?
Old Oct 24, 2003 | 03:28 PM
ZoomZoom's Avatar
Drive it like U stole it!
The rev limiter on the RX-8 is set to kick in at 9,500 rpm. However it sounds like the ECU is programmed to lower the rev limiter to 6,500 rpm until the engine is fully warmed up. I know that this technique is used in the Honda S2K, the engine in the S2K will not V-Tech until the engine is warm.
Sounds like your engine was not fully warmed up when you got to the ramp that day.
Old Oct 24, 2003 | 03:33 PM
Wing's Avatar
That happened to me once leaving work, I was just exiting the my spot and punched it a bit and I really didn't expect it! But then I tried it again about 10 seconds later and it didn't do it.
I think it's smart to have but it will only happen when the car is frozen. Come winter I'm sure more will notice it.
Old Oct 24, 2003 | 03:39 PM
lurcher's Avatar
ex-preorderer
It's normal and is mentioned in the manual; which BTW also recommends a long idle warmup only in very cold conditions - less than -18C/0F - or when the car has sat idle for several days.
Old Oct 24, 2003 | 05:02 PM
Redshift's Avatar
Spinning Dorito Junkie
The engine in the S2K will never V-Tech, since that is a brand of cordless phones.
VTEC, however, is a totally different technology...
Old Oct 24, 2003 | 05:21 PM
Fun, I had a conversation about that the other day.
I friend (and Honda owner) noticed I had V-tech in the kitchen.
Old Oct 26, 2003 | 10:07 PM
f1michel's Avatar
never idle for 90 sec it's a waste a very valuable fuel, by the time you have your seat belt buckled you're ready to drive away, although not at 9 K .
Old Oct 27, 2003 | 01:44 AM
5Gen_Prelude's Avatar
Not sure if this is also true with the 8, but VTEC also won't engage unless you're at WOT. It will allow you to rev to redline as normal though - just the 2nd lobes don't engage
Old Oct 27, 2003 | 07:43 AM
Redshift's Avatar
Not sure I understand what you mean, but either way, I think it's wrong.
If you mean that the computer will not let VTEC engage until the engine has warmed up, that is true. Regardless of WOT or not. (Since VTEC actuation is controlled by oil pressure, it can't/won't engage until proper oil temperature is reached.)
If you mean that the computer won't let VTEC engage unless you are at WOT at any time, well, that's not true. I drove an SiR (and by drove, I mean thrased) and VTEC engages at a set RPM point, not a set throttle position. Trust me.
Old Oct 27, 2003 | 07:53 AM
takahashi's Avatar
Not just the S2K... my B17C Integra Type R (DC2) has no Vtec when the engine is cool
Old Nov 1, 2003 | 02:32 AM
Sorry, I don't trust you. There's actually 10 VTEC points depending on the TP which can increase the cross over point and at very low TP, eliminate it all together. Saying you can't engage it at WOT wasn't quite correct, but saying there's a fixed point isn't either.
Anyway, my point was simply that there are a number of factors (including speed) that decide when VTEC and the secondaries engage, not unlike the 8's
Old Nov 1, 2003 | 03:10 PM
Redshift's Avatar
Well, we both oversymplified to some extent, seeing as how this isn't a Honda discussion board, I didn't feel like getting into it any deeper. I guess you do for some reason. I just wanted to point out that WOT had nothing to do with it.
*shrug*
Regardless, my SiRs cam profile would change over at 5500rpm whether I was at WOT or barely giving it enough throttle to accelerate... assuming the car was warmed up, had consistent oil pressure etc.
Same story on the 2 'Lude SHs, the 3rd Gen GS-R, the 3rd Gen GS-R w/ Type R cams and Hondata computer, 2nd Gen GS-R, 2nd Gen LS/VTEC Hydbrid and the RSX-S owned by my friends.
I'm not saying that the activation point can't vary a little bit, but in the 4 years I was into Honda's I never heard of these 10 specific activation points.
Old Nov 1, 2003 | 06:02 PM
I send you the link if you care.
Old Nov 1, 2003 | 06:58 PM
Redshift's Avatar
Actually, I would like to see it, if you wouldn't mind.
Not that I don't believe you, so don't think that. I'm just surprised I've never heard of it before, and would like to learn more about it.
Old Nov 4, 2003 | 01:40 AM
There's another link I can't find right now but here's one: http://www.hondata.com/techecuanatomy.html
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Nov 5, 2017 09:35 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
rxwilly8
Sep 2, 2015 02:42 PM
