neutral switch
Old Dec 19, 2007 | 12:57 AM
zoomzoom_8's Avatar
neutral switch
What exactly does the neutral switch do? I have the cel code for the neutral switch being faulty or incorrect.
Will a car continue to start up and run with a bad neutral switch?
Thanks guys, i know this one must be an easy question, but I searched and couldn't find an answer.
Chris
Old Dec 19, 2007 | 01:59 AM
po 850..
yes it will start and run. but it will idle funny when it warms..
it will go from 850 rpm to 1500 rpm..
Old Dec 19, 2007 | 02:34 AM
TrochoidMagic's Avatar
is adjusting valve lash
its for a manual trans right?
i'm not sure the bugs involved between the 2. neutral switch and neutral safety switch.
i think the symptom swoope may be describing is for an auto with a neutral safety switch...
but a neutral switch for a manual, all it is is a button by the clutch pedal that grounds the circuit letting the starter turn over. should have NO affect on idle or driveability to my knowledge.
Old Dec 19, 2007 | 02:40 AM
^^well...thats what a neutral switch does. if its stuck in one position or the other...it can either NOT let the car start, if its seized and not letting the circuit ground, therefore not letting the starter get power. or if its stuck/ out of adjustment, it can let you turn over the engine without stepping on the clutch setting the car in neutral...hence the name "neutral switch".
Old Dec 19, 2007 | 03:40 AM
actually-
in the manual transmission of the rx-8 there is a switch that tells the PCM "im now in neutral" if the switch is stuck or faulty it can cause idle hunting issues as the pcm thinks the car is in gear and doesnt understand what to do with the air info its getting from the MAF so its load calculation gets all messed up
Old Dec 19, 2007 | 09:36 AM
ahh.... now I understand.
We had two members who sold there cars because they would put it in neutral at freway speed and the car would die.
Old Dec 19, 2007 | 01:09 PM
Are you sure its not that they removed the Screen inside the intake ?
Old Dec 20, 2007 | 05:49 PM
SilverStreak's Avatar
Zoom hit it dead on about the neutral switch but the same is true of the clutch switch as well. The clutch switch allows you to start the car but it can also cause idle hunting. I had a hell of a time figuring out why my wife's 96 Miata wouldn't idle (almost stall cycling up to 1500 rpm). Tracking through with the OBD II codes, eventually lead me to replace the clutch switch (the cycling would happen with the clutch in when the car was in gear at a stop but disappear when in neutral. Both switches interact with the ECU, good news is that they aren't expensive and they are easy to DIY (at least the clutch switch is).
Old Dec 20, 2007 | 06:31 PM
I think I should look at my clutch switch as well, its an warranty item but lazy *** dealership I told them couple of times it squeaks like **** but they always say *No issues*
*Sigh*
Neutral switch is easy to replace too ... you have to jack your car up tho.
Old Dec 20, 2007 | 06:36 PM
nope.
manual.. have had this problem..
Old Dec 26, 2007 | 03:33 PM
Shinka-05's Avatar
streetfighter
I have had this problem with my idle and threw the CEL, I took it into the dealer, and they checked the nutrual switch and didn't replace it, they said it was fine and all they did was reset my pcm. My car still doesn't idle right, it bounces quite often. I have found that if I put it in gear and put it back to nutral it goes away, but how annoying!
Old Dec 26, 2007 | 03:35 PM
I had a faulty switch as well, idle was all over the place. I've got a thread on here with a video.
zoomzoom: are you still under warranty?
Old Dec 26, 2007 | 04:42 PM
arghx7's Avatar
just some informed speculation here...
on the older rotaries, the neutral switch was used as an input to the ECU to determine whether to activate certain emissions solenoids for the air pump etc, so that could be making your emissions equipment operate incorrectly
Old Mar 25, 2009 | 01:22 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
Thread revival!
Just need some help here... Yesterday and today when I was driving my car and it stalled (rpm just dropped to 0) once I shifted it to neutral at around 30 mph. It was kind of weird because I didnt have any idling problem and it started back up fine... could it be the neutral switch or could it be the intake because I have the AEM intake with only one screen.
Old Mar 25, 2009 | 11:47 PM
not likely the problem, but a symptom of something else.. a bad switch by itself will cause a hunting idle from 900 to 1300 that goes away when you press in the clutch..
Old Mar 27, 2009 | 01:18 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
thanks swoope! the funny thing is it never came back... I think its time for me to get a compression test eventhough I got one from the dealer not long ago, but I just dont trust them.
Old Mar 27, 2009 | 05:26 AM
you might want to pm me your cars info..
i have been through this. i can offer some insight.
Old Apr 10, 2009 | 07:00 AM
PRX8's Avatar
still searching for one .....
Old May 18, 2009 | 02:24 PM
Chris's Avatar
Turbo Member
anyone know of a ball park price to replace neutral and clutch switch, my car slowly idles up to 1000rpm causing a rough idle. This has been going on ever since I had mazda replace my clutch. Also a side note, since the clutch replacement I have not been able to utalize my cruise control. I am guessing this is because of one of these two switches. My car is throwing a CEL for Clutch switch.
Old May 18, 2009 | 10:26 PM
rx8cited's Avatar
Originally Posted by RWD+LSD=Zoom
anyone know of a ball park price to replace neutral and clutch switch....
Switches
Old May 18, 2009 | 10:50 PM
Chris's Avatar
Turbo Member
^perfect
Old May 18, 2009 | 11:05 PM
nope, not always
it depends which mode (on or off) it's failing on, which may not necessarily be the switch itself, it could also be a wiring issue, pin issue at the ECU, etc.
I'm fighting a recurring cel on mine, but have no idle or other issues with it, runs perfect actually, replaced the switch and no change. I'm finally going to break down and trace it through this weekend to figure out the problem once and for all
Old May 19, 2009 | 07:37 AM
Chris's Avatar
Turbo Member
the issue i have is the car hunts at idle up to 1000 rpm which causes the car to shake and even more so when the airconditioning is on. when I say shake it is like right on the brink of stalling would be how it feels. almost an entire chasis shake. I am going to run the codes to find out why the cel is on and i will post more updates
Old Jun 25, 2009 | 02:01 PM
Originally Posted by TeamRX8
nope, not always
Mine turned out to be a simple fix. Apparently when I had the trans rebuilt the rebuild shop installed an aluminum crush washer between the neutral switch and the trans housing. This was preventing the switch from contacting the actuating mechanism in the trans, leading the PCM to always believe the car was in gear. Removing the washer and using some sealant on the switch threads to prevent oil leakage solved the problem. No more CEL.
Old Oct 7, 2010 | 08:22 AM
Lord ET's Avatar
Is that a bike rack?
Sorry to bring up the past...
I've been dealing with my Neutral safety switch giving me a CEL for a couple of months now. Today I finally started to get some fluctuations in idle RPMS while in neutral. Did you guys replace the switch on your own, without dropping the transmission down?
I looked at the switch about a month ago and saw that both leads had the insulation melted off of them for about an inch before the switch housing. I covered them with high temp epoxy and the CEL went away for a while. Now it's back and I think it's time to replace the switch.
So yeah, I tried to reach the switch with the transmission still in place and it seemed damn near impossible. So if you did it yourself I'd really appreciate some tips. Thanks.
