Will It Fit Thread
Rating: Thread Rating: 4 votes, 5.00 average.
Old Dec 18, 2007 | 08:16 PM
BigOLundh's Avatar
#1 Legend
Will It Fit Thread
Since most of the threads in this sub-forum are questions based on "will these rims fit with this setup". Itll be easier to just answer all the questions in one thread.
Ill update this first post with links to basic explanations on how wheels sizes and offsets work. That alone should answer 90% of the questions, but it wont because its easier to post it rather than doing the research first.
Nonetheless... please just post up
Wheel Diameter (F/R)
Wheel Width (F/R)
Wheel Offset (F/R)
Suspensions Changes (i.e. - how low are you dropped. If you have coilovers... you dont need to post this as you can just adjust it after you get your wheels on.
So For Example:
F: 19X10 +28
R: 19X9 +30
Also if you like, if you have a set of tires in mind.. post up the specs to that as well
(W/P/D)
EX:
F: 235/35/19
R: 265/30/19
Many times its possible to make an aggressive wheel fit, by using an equally aggressive tire combination. Obviously this is very dangerous, more likely to lead to your tire exploding, and less protection from potholes and curb damage... but it looks so jDm!!!!
And on this note, please stop PMing me your wheel/tire questions. Just post it here, and those who know... can chime in with the info you are looking for.
Old Dec 18, 2007 | 08:28 PM
rio_rx8's Avatar
I guess ill go first....
How about 19X9.5 all around with a 45-48mm offset....Stock height stock brakes...
"will these rims fit...?"
Old Dec 18, 2007 | 08:30 PM
TragicallyHip's Avatar
IfYerNotWasted..TheDayIs
F: 18x8.5 +35 (Option 1)
F: 18x9.5 +35 (Option 2)
R: 18x9.5 +35
Tires on those rims would be:
F: 235/40-18 (Option 1)
F: 275/35-18 (Option 2)
R: 275/35-18
Old Dec 18, 2007 | 08:35 PM
BigOLundh's Avatar
#1 Legend
ALRIGHT - our first victim.... err i mean participant.
The rear will be tucked in a bit by about 1/4" from the fender, but other than that there should be very minimal issues. Definetely wont need a fender roll.
The front will probably fit as well, but you are chancing rubbing on the inner fender when turning the wheels. Ooh, and on this first example... you maybe able to get away with this by running a stretched tire upfront. You wont need anything two agressive, but just a 255/35/19 should work.
If possible... test fit the rear wheels on the front, before buying all 4.
Althought, i would think its better to get a different setup.
I maybe wrong about the front wheels, so we'll see what other say. Possibly those who have tried this themselves.
Old Dec 18, 2007 | 08:38 PM
BigOLundh's Avatar
#1 Legend
R: 18x9.5 +35
R: 275/35-18
Option 2 sounds similar to the RPF1 setup everyone is running. Should be fine.
Option 1 will work as well... but your front wheel will be sitting .5" fruther in then the rear wheel (i.e. not flush)
Old Dec 18, 2007 | 08:41 PM
rio_rx8's Avatar
Thanks alot for the input and thread...I just want to be 110% sure if im gonna be ordering wheels online...and since i live on guam...shipping wheels back because they dont fit is gonna be a hassle to deal with...
thanks though
Old Dec 18, 2007 | 08:57 PM
nuke0907's Avatar
Never Blend In
haha, i thought this was gonna be a thread to post wheel specs that work. i was gonna post my specs. i didn't actually think you would make a thread to answer everyone's questions.
Old Dec 18, 2007 | 09:19 PM
rglbegl's Avatar
Baned
18x8.5 +37?mm 245/40/18 front
18x9.5 +38?mm 275/35/18 rear
Sittin on tein s-tech I have NO rubbing issues at all.
Old Dec 18, 2007 | 09:28 PM
rio_rx8's Avatar
you could still post your wheel specs...im sure it will help someone whos thinking of running a similar setup
Old Dec 18, 2007 | 09:39 PM
nuke0907's Avatar
Never Blend In
19" Axis Matrix with Toyo Proxes T1R
F: 19x8" +35mm 235/35/19
R:19x9.5" +40mm 265/30/19
lowered on Tein S-Techs.
no rubbing. i really wish the fronts were 8.5" at least. the rears are perfect.
Old Dec 18, 2007 | 09:55 PM
scsi's Avatar
check this out
Rear
18x10 +41, 285/35/18
Old Dec 19, 2007 | 03:59 AM
TrochoidMagic's Avatar
is adjusting valve lash
^^that is mad sick dude.
Old Dec 19, 2007 | 04:01 AM
paulmasoner's Avatar
Asshole for hire
Yo hS, how about this idea, will it fit?
18X8 +50 wrapped in 225/45/18
Please tell me it will work, i think this would look sweet!
btw, if 3 Shades of Brown doesn't get their act together and step it up, you may have to find a new manger
Old Dec 19, 2007 | 05:00 AM
effie's Avatar
Nightmares be gone...!!!
ok...my turn...
Will these fit....?
19x9 offset 25 front
19x10 offset 25 rear
Im guessing id have to run some major negative rear camber to get it to fit.... Definately need to roll the fenders right....
tyre wise im thinking
235/35/19 front
275/30/19 rear
Old Dec 19, 2007 | 05:08 AM
BigOLundh's Avatar
#1 Legend
Originally Posted by effie
ok...my turn...
Will these fit....?
235/35/19 front
275/30/19 rear
HELL YESS!!!!
225 35 up front
225 35 in the rear...
Push Out, Camber In, Stretch = FTW!!!
Old Dec 19, 2007 | 05:09 AM
BigOLundh's Avatar
#1 Legend
Originally Posted by scsi
check this out
Rear
AKA PERFECTION
-hS
Old Dec 19, 2007 | 10:38 AM
rglbegl's Avatar
Baned
Since we are adding pictures, this gives me a chance to quote myself.
Old Dec 19, 2007 | 12:44 PM
BigOLundh's Avatar
#1 Legend
It will fit, but itll look like poo. Sunken Battleship Rims especially when aftermarket... not a good idea. I suggest bringing them about by at least 25mm.
F u haole boy. 3 Shades Of Brown will not allow your people to invade the band and steal our lands.
CHEEEEEEEEEEEEEEE HU
Old Dec 19, 2007 | 12:55 PM
Kane's Avatar
19 X 9.5 +28mm Rear 225/35
19 X 8.5 +28mm Front 245/35
Rear has to be rolled; front is fine.
On the Left...
Old Dec 19, 2007 | 01:39 PM
BigOLundh's Avatar
#1 Legend
kane - what rims is that on your FD?
Old Dec 19, 2007 | 01:47 PM
Kane's Avatar
AME Circular Spec-R BBF Finish 18x9 and 18x10
Old Dec 19, 2007 | 02:11 PM
pdxhak's Avatar
Official Post Whore
F: 19x8.5 +40mm 255/35
R: 19x8.5 +40mm 255/35
Tein Flex Coilovers
Old Dec 19, 2007 | 02:35 PM
BigOLundh's Avatar
#1 Legend
thats hot
cant go wrong with AMEs
Old Dec 19, 2007 | 04:21 PM
Easy_E1's Avatar
This is what I have and no issues,,,
F/R 18 x 8.5 38 mm offset
F/R 265-35 x 18
Old Dec 19, 2007 | 07:23 PM
OK, so I NEED to make up my mind tonight on what I am going to do about rims/tires...
Big-O, I know you said that the 275/35-18's sounded similar to the RPF1 setup everyone is using, but mine are +35 while they are all running +45... I DO NOT want to have to roll my fenders, so i'm nervous to go with the 275's...
I need to know if 18x9.5 in 275/35-18 (+35) will fit FOR SURE in the rear without rubbing...
If not, I need to know the widest I can go in the rear with a +35 offset, on an 18x9.5 rim... AND NOT rub.... I only have until Friday to make my order
I
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
