Anyone have their motor mounts replaced more than once?
Old Dec 7, 2007 | 10:22 AM
Vasichko's Avatar
For the past couple of days Ive noticed a rough idle, so I think Im gonna replace the plugs and coils since I have just over 27k miles on them.
Hopefully this clears it up, but the symptoms look as if it would be the motor mounts again.
Anyone have these replaced multiple times?
Old Dec 7, 2007 | 11:20 AM
I'm about to have it done. I got them replaced about a year ago and now it seems as if I need another mount.
Old Dec 7, 2007 | 11:40 AM
MazdaManiac's Avatar
Mine are abused by the turbo, so I'm probably not a good data point.
But, yes, mine keep failing.
They get floppy and sag.
I have one that I filled with urethane in the car right now.
I'm just not so sure I like the vibration.
I'm going to try filling one with 60 Shore instead of 80 and see if it is any smoother.
Old Dec 7, 2007 | 11:43 AM
MM: have you tried Mazsport's Motor mounts? (I'm assuming they're different then OEM?)
Old Dec 8, 2007 | 07:41 PM
Talk about mount... It looks like someone is getting mounted in Jeff's new Avitar!
Old Dec 8, 2007 | 08:33 PM
No. Ray has them, though.
I don't really need the space that they provide and my solution doesn't cost me anything.
Old Dec 9, 2007 | 09:19 AM
1stgen8's Avatar
Where and the heck does he find all the pics. I'm starting to think he knows alot of the girls.
Old Dec 10, 2007 | 05:50 PM
Vasichko's Avatar
Yeah cause for maybe a week now the idle feels more rough in the shifter and feels like things are moving when I hit certain bumps.
Wonder if one of the techies forgot to do something when putting my car back together when doing the warranty for a throw out bearing.
Old Dec 15, 2007 | 04:04 PM
Vasichko's Avatar
Well took it to Mazda they said they checked everything and everything is ok.
I still dont believe so, the car feels like it shakes and rattles alot more over roads.
If I tap the throttle and let off you can feel it rock back, rock forward, then it does so 2-3 more times with each time getting less pronounced.
Anything else this could be?
Old Dec 15, 2007 | 05:23 PM
I replaced mine about a year something ago, and I just replaced it again last month, both warranty
Old Dec 16, 2007 | 11:49 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yup same here. I got the shakes This one will be out of pocket. I'm out of warrenty.
Old Dec 17, 2007 | 12:13 PM
Cody Red's Avatar
always filling [the c]up
where's a good place to buy them? I'm gonna need some soon, and dealer said mine were fine.
Old Dec 17, 2007 | 12:17 PM
check around, msg onlinemazdaprts and medcentermazda and RosthenlMazda
Old Dec 17, 2007 | 01:57 PM
So, why are they failing?
Poor design?
Or just too much heat?
Old Dec 17, 2007 | 05:24 PM
Vasichko's Avatar
Im actually considering getting the Mazsport motor mounts, I think they are $250.
Try to get the dealer to fix mine and install the other ones when I get time.
drebbrnator
Dec 27, 2018 07:02 PM
PotatoCannon
Sep 6, 2015 11:48 AM
Glaxzor
Aug 21, 2015 09:26 PM
Shinka84
Aug 19, 2015 04:55 PM
vetteor8
Aug 9, 2015 05:56 PM
