How do these plugs look?
Old Dec 4, 2007 | 11:11 PM
WpgDSMer's Avatar
I had the dealer change my plugs and do a compression test while I had it in for an oil change (got hosed on the plugs, but that's another story).
I got the car a few months ago, and wanted a baseline to go from.
I had them return the used plugs to me, and have the photos attached. Do these seem to have excessive carbon build up on them? I know it's an issue on these cars, but I have not seen plugs that looked like this before (previous car was a turbo 4cyl). Excessive or normal?
These are the stock plugs (as far as I know). The car is an 04 6spd with 44,500km on the odo [approx 27,650mi]
FYI
compression came out 7.6, 7.6 and 7.7 kgf/cm^2 on the front rotor
and 7.5, 7.6 and 7.5 kgf/cm^2 on the rear.
Std value is 8.5 and minimum is 6.9, so it's a bit low, but at least consistent across all readings.
Attached Thumbnails How do these plugs look?-img_0020b.jpg   How do these plugs look?-img_0021b.jpg   How do these plugs look?-img_0022b.jpg
Old Dec 4, 2007 | 11:36 PM
TrochoidMagic's Avatar
is adjusting valve lash
WOW! that is dirty. how many miles those plugs got on them?
Old Dec 4, 2007 | 11:46 PM
Silver_Surfer's Avatar
I4NI
Yeah, Looks like youre running alittle rich or you premixing too much oil?
The threads looks oily?
Old Dec 5, 2007 | 12:14 AM
WpgDSMer's Avatar
Only owned the car since September. Mileage is listed in the original post [27,650mi].
I haven't used pre-mix or synthetic or anything like that yet, thou I plan to. I try to take the rpms up each trip, and my drive to work isn't that short (30 min or so) so I don't do a lot of short trips.
When I checked the history of the car, Mazda said all recalls were performed without issue. Is there an engine flash that wasn't a recall that I might not have yet?
The high carbon is the main reason I was looking at the Amsoil Interceptor pre-mix instead of the Saber (see recent posts in the pre-mix sticky). It says that it has a lot of anti-carbon build up additives.
My best guess is that the previous owner did not run the engine up to burn off excess carbon, and it just accumulated. As for the oil on the threads..??? The deposits on the spark plug are dry (powdery) not oily.
Old Dec 5, 2007 | 12:45 AM
ZoomZoomH's Avatar
Mulligan User
those compression numbers are actually pretty good, it's not how high they are, it's how even they are, and frankly that's damn consistent for all sides and both rotors.
now rev that bad boy and keep it healthy!
Old Dec 5, 2007 | 01:12 AM
the plugs look well pampered, not good.. i would say flog the hell out of them, but my guess is you replaced them..
so flog the hell out of the new ones..
Old Dec 5, 2007 | 07:51 AM
peterlemonjello's Avatar
27k is getting up there for 8 plugs. Thanks to the recall and some hard starts the dealer has been changing mine every 12k
Look into Idemitsu premix.
Old Dec 5, 2007 | 08:19 AM
Damn ...
Its time to drive it like you stole it.
the compression seems fine. its not very good. but its ok.
Might want to look into premix, I use Idemitsu right now.
Old Dec 5, 2007 | 09:36 AM
The center is light tan, which is what you want.
The rest of th eplug gets black like that from sitting at idle too long. DD driving.
Old Dec 5, 2007 | 11:26 PM
Old Rotor's Avatar
What was the RPM's of the test? You might want to change your Air Filter, get some more air in the engine and run leaner and cleaner. Here are mine...
https://www.rx8club.com/showthread.p...20#post2153320
Old Dec 5, 2007 | 11:32 PM
DarkBrew's Avatar
Extraordinary Engineering
For comparison here are my plugs
https://www.rx8club.com/showpost.php...48&postcount=1
Old Dec 6, 2007 | 12:47 PM
WpgDSMer's Avatar
Not sure what the RPM was during the compression test. The work order said it was a compression test as per the recall test for engine replacement. I'm hoping the Mazda dealer ran it at the correct RPM, and/or has the equipment to measure and compensate for the actual speed.
Thanks for the additional photos. It looks like the car was probably being babied. I'm going to be getting a new filter and babying it wont be an issue with me driving, so hopefully when these new ones come out they'll look a little better.
Old Dec 6, 2007 | 02:44 PM
kennyfrc1's Avatar
BG44k
Old Dec 6, 2007 | 03:24 PM
DOMINION's Avatar
I don't buy Kool-Aid
You know this is the 2nd time I have seen some bad plugs like that. That last one I seen was from that dude down under, I cant recall his name, I think its Taka.
I'm about to change mine. I wonder what they will look like.
-Gil
Old Dec 6, 2007 | 06:10 PM
Railton's Avatar
FYI
I strongly suggest you find out what RPM the motor was turning over before you make a call on how good the numbers are. The higher the RPM the higher the compression ratio will be.
Find out the RPM's and use the chart attached.
Railton
File Type: pdf
Old Dec 7, 2007 | 10:28 AM
Vasichko's Avatar
Dont mean to hijack, but anyone know the cheapest/best place to get plugs/coils?
Im on that 27k mark on both right now, idle has gotten a bit rough, and needing to replace them to see if thats the issue or motor mounts for the 2nd time.
Old Dec 7, 2007 | 12:59 PM
Old Rotor's Avatar
Here is a Post with ideas. I got on E-Bay...
https://www.rx8club.com/rx-8-discussion-3/spark-plugs-cheap-107791/
Old Dec 7, 2007 | 01:47 PM
staticlag's Avatar
The Professor
sparkplugs.com for the plugs
and
onlinemazdaparts.com for the coils
Old Dec 7, 2007 | 01:48 PM
staticlag's Avatar
The Professor
pics are kind of far away, they look like your running rich or the plugs are fouled.
Old Dec 10, 2007 | 11:40 AM
MacSav's Avatar
Another Comparison After 20k
I think they look awful...
Old Dec 10, 2007 | 05:57 PM
Can you feel that your 8 said thank you to you? Just right after you took those out
Im about to do mine. oh crap I forgot to order trailing plugs. Sparkplugs.com here I come !
Old Dec 10, 2007 | 07:18 PM
Old Rotor's Avatar
How many miles? Did you change your air filter? What type of driving do you do?
Short trips? Give us some more info please....
Old Mar 19, 2008 | 05:35 PM
RX8 dood's Avatar
http://www.mazsport.net/store/index....&p=23&added=23
Would these NGK spark plugs be a good replacement for my 8? it has 44000 and I can bet they haven't been changed a good while.
Old Mar 19, 2008 | 09:38 PM
Old Rotor's Avatar
Those would work for about 20K miles...they are not the correct OEM plugs.
The stock OEM plugs that are recommended and installed in new RX-8 are these NGK ones on the bottom of the page and should have no problem going 30K miles...
http://www.sparkplugs.com/results_ap...1&AAIA=1416844
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
WranglerFan
Aug 21, 2022 01:29 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
iphil
Sep 21, 2015 10:49 PM
Vedivan1
Sep 18, 2015 12:39 PM
