Best Motoring Jan. '08 EvoX vs. STI and Evo IX
Old Dec 4, 2007 | 02:53 PM
Ike's Avatar
Ike
Blue By You
http://youtube.com/watch?v=9XzEvDckku8
Old Dec 4, 2007 | 03:12 PM
Renesis_8's Avatar
Never buy the SST! It sure looked boring to drive it on the track.
________
Wellbutrin classaction
Old Dec 4, 2007 | 05:25 PM
terrypk1's Avatar
lol sst seems pretty slow compared to the manual evo9. of course there is teh weight difference.
Old Dec 4, 2007 | 05:33 PM
Ike's Avatar
Ike
Blue By You
I would blame it overheating on that... However, when the Evo 9 rocketed by I think it was only the second lap and the overheating problems didn't really show up until the 4th lap. I'm still reserving final judgement but I've gone from someone that will probably buy the Evo X to someone that will test drive it with much doubt.
Old Dec 5, 2007 | 12:41 AM
saturn's Avatar
i pwn therefore i am
The SST they were using was having overheating issues at high rpms. Also the guy driving it had incredibly odd shift points. I don't know if he was trying to let the computer determine everything (there may in fact be no way to force the computer to not shift for you even in manual mode), but it didn't seem right. I will reserve judgement till I see a SST tested that I could actually buy.
Old Dec 5, 2007 | 01:04 AM
Steiner's Avatar
Interesting. Too bad they couldn't throw the new 2008 STI into the mix.
Old Dec 5, 2007 | 01:31 AM
Ike's Avatar
Ike
Blue By You
It wasn't overheating during the first couple laps... If you're referring to shiftpoints after that it was because the cars computer was making the car shift early due to the tranny overheating.
Old Dec 5, 2007 | 02:47 AM
faboo's Avatar
Downhill Touge FTW!!
hmmm....i wonder why tsuchiya drove the skyline...he likes balance and low weight...not big and powerful
Old Dec 5, 2007 | 07:48 AM
Renesis_8's Avatar
he just tagged along to have some fun, you notice when he fell back to last he was drifting through corners. They knew the G35C was no match for all of the turbo AWDs out there.
________
Digital easy vape instructions
Old Dec 5, 2007 | 08:24 AM
I saw it yesterday.
I was like wtf ? it overheats ? wow, Good bye Mitsubishi !
Old Dec 5, 2007 | 01:18 PM
Ajax's Avatar
What I want to know is why the EVO9 was so much faster than the X.
I realize the EVOX is a little heavier and has slightly more horsepower, but the difference was much more dramatic than I thought it would be. In fact, I figured the X might even be slightly faster.
Was there some other major change?
Well, apparently autoblog already has the answer.
The guys in japan tested the X and the NEW STI on the track recently too.
See below:
http://www.autoblog.com/2007/12/05/e...uba-lap-times/
Old Dec 5, 2007 | 01:32 PM
Ike's Avatar
Ike
Blue By You
See below:
The problem is you're trusting manufacturers HP ratings. The Evo has been underrated from the factory for a while, the new one with the new powerplant is probably a more accurate portrayal of actual horsepower. So, couple what is probably a little less horsepower in a heavier car and there you have it.
Old Dec 5, 2007 | 02:01 PM
Steiner's Avatar
See below:
Good find! I'm excited to see one of these type of comparisons using the USDM models at a track like Laguna Seca. There are a lot of factors to consider if you're a current Evo/STi owner and you're planning to purchase one of these two new cars, but I'll have a helluva time pulling the trigger on the new STi if it doesn't handle as well or better than my old Evo VIII...stock for stock of course.
Old Dec 5, 2007 | 02:04 PM
delhi's Avatar
Grand Chancellor
See below:
Looks like a sparring match with each model year's car trading punches. However of late the STi is doing better. Maybe this track doesn't favour the EVO.... and that err given the right conditions the EVO is better. Sounds familiar?
EVO/STi
2006 1:05:07 / 1:04:72
2005 1:04.88 / 1:04:17
2003 1:05:30 / 1:04:69
2001 1:05:17 / 1:06:56
1998 1:04:69 / 1:06:73
1996 1:07:00 / 1:05:92
1994 1:06:52 / 1:06:26
1992 1:10:90 / 1:07:99
Old Dec 5, 2007 | 02:10 PM
Renesis_8's Avatar
What are you gonna get now Ike?
________
Volcano vaporizer
Old Dec 5, 2007 | 02:11 PM
Renesis_8's Avatar
EVO/STi
But they're both Turbo AWD...
Did Mitsu really moved the engine FURTHER up? While Subaru lowered their engine.
________
condo for sale Pattaya
Old Dec 5, 2007 | 02:53 PM
Ike's Avatar
Ike
Blue By You
EVO/STi
Those numbers are a bit misleading since most of the better STI numbers are probably from super limited production cars such as the Spec C and S201/202/203/204 etc. In fact I'd like to know where the listed times come from and exactly what model they are using because in most cases those times don't match up to any of the times I've seen for either car...
In most publications, and Best Motoring in particular the Evo bests the STI year after year after year (though it's always close). It's the same story each year, Evo is a better drivers car, it has better steering, turns a slightly better lap, and the STI understeers more. They're so close that which is the better car simply depends on what you want in a car, the slightly better performer, or the slightly better dailer driver. However, I have a feeling the gig is up for Mitsubishi this year and Subaru may be better at both. We'll need some more time to sort it out, but it's not looking good for the Mitsubishi camp.
Old Dec 5, 2007 | 03:06 PM
delhi's Avatar
Grand Chancellor
^ Same can be said of the EVOs too. MR, Makkinen edition, etc. Who knows...
Old Dec 5, 2007 | 07:18 PM
Ike's Avatar
Ike
Blue By You
No, the MR isn't much more than an options package and they lap VERY similar to any other Evo. Cars like the Spec C are alittle more worked over and have more power, usually weigh about 150 lbs less than a regular STI, and have lots of things to tighten up the suspension, and finally are quite a bit more expensive. It's Subarus group N homologation car.
Old Dec 5, 2007 | 10:16 PM
dillsrotary's Avatar
jersey fresh
I believe the X has it's engine slightly pushed forward more compared to the XI which would effect it's times some.
Old Dec 5, 2007 | 10:26 PM
Ike's Avatar
Ike
Blue By You
I highly doubt that's nearly as much of a factor as the increased weight and what is most likely less power despite the higher manufaturer ratings.
Old Dec 5, 2007 | 10:45 PM
rollerbldes's Avatar
Isn't the SST the only option here in the US?
Old Dec 5, 2007 | 11:15 PM
Ike's Avatar
Ike
Blue By You
Nope, it comes with the MR. The GSR model has a 5MT.
Old Dec 5, 2007 | 11:40 PM
saturn's Avatar
If anything, the differences between the STi and Evo have widened dramatically with these new models making the decision much easier for most people. You're now comparing a relatively raw-feel hatch to an sophisicated electronic coupe.
Even when the differences were very minor in years past, many people were very much in one camp or the other for very basic reasons (e.g. - cosmetic, interior comfort, mileage, etc). Now that both cars have changed fairly dramatically the decision is easier and the camps will become more well defined. They will both be considered very competent performers with large cosmetic and feel differences. I don't think there's much chance of the Mitsubishi camp becoming empty.
Old Dec 6, 2007 | 12:26 AM
tajabaho1's Avatar
Destroying Threads
so mitsu made a car that is slower than it's predecessor?
it pulled a mazda huh
