why are 04 RX-8's faster than any other RX8's?
Old Nov 28, 2007 | 08:03 PM
callee's Avatar
RX7 whore....!
Question why are 04 RX-8's faster than any other RX8's?
We did a little test because I didn’t believe at first but after 10 runs between a 04 rx8 w/ 42k miles and a 06 rx8 w/ 13k miles... the 04 rx8 wins it!!
Both stocks!
Any ideas????
Old Nov 28, 2007 | 08:05 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Both stocks!
Any ideas????
Ohhhhhhh....I think I'll just let this one slide right on by without making any comments!
///aldo's Avatar
by how much.. who was the better driver? ect ect
Old Nov 28, 2007 | 08:08 PM
4me2's Avatar
04's weigh less. ^ 0-25mph street racing?
Old Nov 28, 2007 | 08:10 PM
Soravia's Avatar
Maybe it was a Sport Vs GT and there's difference in weight? Maybe someone is driving better? Maybe one car has better engine management?
Old Nov 28, 2007 | 08:14 PM
Mazurfer's Avatar
Still missing a few possibilities guys....C'mon
Old Nov 28, 2007 | 08:20 PM
rowteree's Avatar
rumor has it as rotaries age, they become faster since they are already fully broken in
Old Nov 28, 2007 | 08:24 PM
///aldo's Avatar
chuck norris was driving the 04
Old Nov 28, 2007 | 08:28 PM
rowteree's Avatar
i heard when chuck norris does push ups he doesnt push himself up, he pushes down the earth
Old Nov 28, 2007 | 09:24 PM
thecow135's Avatar
so mike huckabee says
Old Nov 28, 2007 | 09:28 PM
callee's Avatar
RX7 whore....!
we both traded cars!! 5 times each!!
and
NO ... to street racing!
we did it indoors at my grandfather's old factory! (its big)
but
Seriously guys....
Why are the 04's faster!???
Its wins by a few inches
Old Nov 28, 2007 | 09:40 PM
tajabaho1's Avatar
Destroying Threads
it has more miles, which means older, older rotaries = faster (if they don't loose compression)
Old Nov 28, 2007 | 09:42 PM
4me2's Avatar
tires?
Old Nov 28, 2007 | 09:49 PM
jones75254's Avatar
Making a pretty bold generalization arent you? Because this ONE 04 is quicker than this ONE 06, that makes 04's the fastest?
....mind you i own an 04, so i would like for this to be the case, but lets get real here. We would need a much larger sample base to be able to make such a claim.
Old Nov 28, 2007 | 11:10 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Both stocks!
Any ideas????
06's engine isnt broken in yet, as rotaries get older they get faster! As mentioned above
Old Nov 28, 2007 | 11:36 PM
alnielsen's Avatar
Yep, It's true. The engine will be it's fastest just before it pukes its guts out (i.e. blows up).
Old Nov 28, 2007 | 11:52 PM
Old Rotor's Avatar
and
but
Seriously guys....
I have had seven rotary cars and it is true that they do get stronger after you put a few thousand miles on them. The car has less frictions after the surface's smooth out and open up ever so slightly. We call it the engine has loosened up.
Old Nov 29, 2007 | 12:17 AM
N rider89's Avatar
^NieL
they get better with age, then die.
Old Nov 29, 2007 | 12:34 AM
SkyLee's Avatar
gets faster in age
Old Nov 29, 2007 | 03:02 AM
eviltwinkie's Avatar
Uhhh...most engines are at their "fastest" when they puke their guts out...that's generally one of the most common contributing causes of failure...
heh
Old Nov 29, 2007 | 03:03 AM
you talking about engines or your date?
Old Nov 29, 2007 | 03:27 AM
TrochoidMagic's Avatar
is adjusting valve lash
though rotaries get faster with a few miles on it, it may be true. the carbon buid-up raises compression giving it better performance, but consequently at its oldest in age with so much buid-up it'll eventually blow the motor. but the truth behind this isn't exclusive to rotaries, such car's as NSX has been said to have the most horses after 45k.
racers have said the rotary is at its strongest before breathing its last breath...sad to say.
Old Nov 30, 2007 | 03:39 AM
enforcer's Avatar
Callee to put it nicely, without some validity of the experimental findings it....
Old Dec 1, 2007 | 07:24 PM
Crztrtldck's Avatar
Jonathan
nooooo!
my beautiful 04
never!
Old Dec 2, 2007 | 06:10 AM
valpac's Avatar
Ahead of its time
a win by inches? well within the margin of error. hell, wind speed and direction could be the answer. you cannot claim a victor based only on your limited test.
