My stereo setup so far
Old Nov 21, 2007 | 05:05 PM
nuke0907's Avatar
Never Blend In
*UPDATED PICS ON POST 12
well i finally got some pics of my stereo setup i have so far. some of you may remember my old thread that i posted some teasers of what i had in mind.
first i started off by installing an OEM iPod adapter several months ago. i mounted the control module under the hump in the center of the dash where the NAV would go and ran the connector plug to my glovebox.
i connected the remote turn on lead to the center outlet. it tapped into the green wire as you can see
ran the remote turn on lead under the seat to the passenger side and fed it through to the trunk. i also ran the 4GA power wire down the passenger side. i decided i would drill a hole in the firewall just behind the washer resevoir.
i tapped into the rear speakers of my non-bose system and attached some pigtails i made from some wire i got a walmart.
then i connected my pigtails to my LOC and ran my signal wires. i used the PAC SNI-35.
i decided to go with the other amp i had, a Kicker ZX750.1
here's some of my almost finished pics of the setup. as you can tell i added some of RotaryRasps trunk LED's.
i decided to mount my capacitor to the back of the Znclosure box i got. it's a Tsunami 2 farad capacitor that is triangle shaped. it faces in the front of the cabin where the pass-through panel goes. it fits perfectly behind the panel with the back tray portion removed.
so far my only plan to finish it off is to build an amp rack to help dress my trunk up a little better. if i'm really crazy , i may decide to go with a corksport kit and get a double din flat panel headunit. thanks for taking the time to read my thread. hopefully this might help some people installing subs in their 8's. let me know what you think of it so far and any suggestions on mounting my amp.
Old Nov 21, 2007 | 05:31 PM
firebirdude's Avatar
User and Abuser
Last setup was two 15" L7's in a hatchback..... what more need I say? Loud.
Old Nov 21, 2007 | 06:08 PM
mbrule6465's Avatar
Rex8
Awesome look. Here's what I've done with mine.My stereo setup so far-subs-rx8.jpg
Old Nov 21, 2007 | 06:21 PM
nuke0907's Avatar
Never Blend In
Originally Posted by mbrule6465
Awesome look. Here's what I've done with mine.Attachment 110815
hmm, interesting. i have one of those triangle subs in my 240. that box wouldn't fit in my 8 though.
Old Nov 22, 2007 | 01:52 AM
WikkedOne's Avatar
Deals on wheels
setup looks good man - i love the LEDs in the trunk!
my only suggestions for now is to not use the shitty t-clamp wire taps.. cut the wire and solder and shrink wrap it... trust me.
and hide your wires!! - cut a little slit into the carpet and run the wires under the carpet - it will clean up the look a TON.. if you have a problem with the carpet bulging up put a peice of 1/2 inch plywood under the carpet under the amp (also so you can screw the amp into it) and then run the wires along the edge of that..
and my OTHER suggestion is to replace all the stock speakers ASAP - a good time to do it is when you get your corksport - because then you can use your new HU pre-outs for the signal insteal of tapping in somewhere.. but thats for the future.
Good job though.. I like!
Old Nov 22, 2007 | 03:27 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
im not really sure where did you connect the remote turn on.... so is it the center cigarette lighter outlit? i kinda got the idea but just trying to make sure
Old Nov 22, 2007 | 07:51 AM
mbrule6465's Avatar
Rex8
There are trays available to place in the trunks' well that come with covers. Take a look.My stereo setup so far-sta_0022.jpg
Old Nov 22, 2007 | 08:15 AM
nuke0907's Avatar
Never Blend In
yes, thats where i connected it. all i needed to do was remove the passenger side seat bottom and the ceter console. then i ran the wire under the seat. i think its the best solution since its not very far to run the wire.
Old Nov 22, 2007 | 08:20 AM
nuke0907's Avatar
Never Blend In
There are trays available to place in the trunks' well that come with covers. Take a look.Attachment 110847
Attachment 110848
i think what i'm gonna do is build a frame around my amp. then i will put a cover on that which will be flush with the trunk. there will still be a hole on top to see the amp. then the wires will just run through the side of the frame from underneath. after that there will only be an inch or so of wires showing and also giving the amp a flush cleaner look.
Old Nov 22, 2007 | 11:40 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
thanks just finished my system!
Old Dec 29, 2007 | 04:05 PM
nuke0907's Avatar
Never Blend In
finally done for now
i finally got around to building a frame for my amp. i think i'm done modding the stereo so far. here's some pics of it:
Old Dec 31, 2007 | 12:11 AM
jb4wc's Avatar
looks good brother
Old Dec 31, 2007 | 09:31 PM
nuke0907's Avatar
Never Blend In
Originally Posted by jb4wc
looks good brother
thanks. i'm lovin it.
Old Dec 31, 2007 | 09:41 PM
G3tR3DDY2GR3DDY's Avatar
could you have done something more to hide the wires? ill have to get some pics of what i did... i dont think ive seen anyone do it so far..
Old Dec 31, 2007 | 10:00 PM
nuke0907's Avatar
Never Blend In
well some amps have covers that hide the wiring, but this one didn't. if it would have i coulda drilled the holes from the bottom. i also could have made another layer on top that would have framed out the amp more, but then it wouldn't be flush.
i think it looks a lot nicer now the way it is framed. i didn't like how it just sat in the trunk well with the wiring completely exposed.
Old Dec 31, 2007 | 10:05 PM
shinka213's Avatar
Pettit fangurl <3
very sweet....
i bet it sounds really hawt!
Old Dec 31, 2007 | 10:10 PM
shinka213's Avatar
Pettit fangurl <3
my trunk
just a couple of kenwood 10s....self powered
painted the grills in BCM to match the car....
nothin fancy but it works for me...
i need the bottom of the trunk for storage and work related stuff...
Old Dec 31, 2007 | 10:22 PM
nuke0907's Avatar
Never Blend In
looks nice shinks. i'm thinking of painting my grill gloss black.
crimson809
Aug 14, 2016 10:03 PM
hufflepuff
May 30, 2016 10:45 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Wurromurro
Sep 20, 2015 05:02 PM
