Need Help with the 12000K HID replacement >~<
Old Nov 21, 2007 | 04:15 AM
philipchan's Avatar
I bought the replacement D2S 12000K HID bulbs, just replaced them today, but after i turn on the lights , they will go off about the same time in about 10~15 seconds, if I turn them off and on again,they light up for 15 seconds again, can't stay for long , dont know what's the problem, need help...PLZ....
Old Nov 21, 2007 | 04:35 AM
Spinning Sushi's Avatar
I <3 Sushi
Could be that 12000k is too high and the HID ballasts shuts them off to prevent any further damage to your car.
Old Nov 21, 2007 | 05:32 AM
philipchan's Avatar
It is possible to get a better HID ballasts so that I can use the 12000K s?
Or is it really hard to change them coz the HID ballasts is from Factory?
Old Nov 21, 2007 | 04:52 PM
XLR83N's Avatar
i had a similar problem with 8000K bulbs but only 1 of them turned off. After sending them back twice, the 3rd set are going strong
Old Nov 21, 2007 | 05:25 PM
the bulbs are inferior quality; stock balast should be able to handle it.
GET RID of them, save yourself the trouble of the ticket. Also, you do realize that visibility will be extremely compromised with that, right????
Old Nov 21, 2007 | 06:48 PM
NgoRX8's Avatar
running 12k on stock ballasts are fine. it has to be the bulbs.
Old Nov 22, 2007 | 03:34 AM
philipchan's Avatar
I see, thankyou guys...It may be the problem of the blubs...I should send them back...and also get rid of the 12000Ks......6000Ks or 8000Ks???
Old Nov 22, 2007 | 03:50 AM
chancejat's Avatar
Drive it like u stole it!
go with 8000..........there legal.......enough
Old Nov 22, 2007 | 11:44 AM
depends on the look you're going for. If you want a slightly "bluer" look, 6k should do the trick. Remember, the higher the number, the more ultra violet you get and less visibility
TeslaMSI
Dec 10, 2015 01:10 AM
TJSiegrist
Sep 10, 2015 09:29 AM
wayloco
Sep 1, 2015 09:03 PM
beastman_5
Aug 30, 2015 10:22 AM
dylan424
Aug 21, 2015 06:10 PM
