Squealing when i brake
Old Nov 21, 2007 | 01:43 AM
saranglinux's Avatar
So.....i checked my brake pads and they are all fine and i still get this squealing noise when i press on the brakes. The weird thing is, when i press down the brakes hard, it wont make the sound but when i am stopping my car at a slower rate and pressing on the brakes "softly" it makes the sound. I took it to my dealer to have it checked out and they said that it was fine. I took out my car for a drive and IT STILL MAKES THIS ANNOYING SOUND. Pls tell me if neone else has/had this problem and tell me how to fix it?
Old Nov 21, 2007 | 08:43 AM
costello's Avatar
You basically have to take the pads off and re-apply the brake grease between the shims pads again. You can get the stuff at Pep Boys, Autozone, etc.
Old Nov 21, 2007 | 09:41 AM
w0rm's Avatar
PUSHER ROBOT
There may be a related TSB on the issue if you have not had it performed already.
Old Nov 21, 2007 | 11:30 AM
Old Rotor's Avatar
Here is the "TSB" for the brake squeal problem. Please print out and bring to your Mazda dealer, then let us know how it goes.
http://www.mstore2000.com/PDF_Files/04-001-06-1568.pdf
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
