My Engine Flooded? Is is covered by Warranty?
Old Nov 19, 2007 | 08:39 AM
dntx5b9's Avatar
after 3 and half years of driving my 2004, I may have just experienced my first engine flooding. I couldn't start my car. My last drive before that was starting the car to move the car from the drive way in to the garage. I have done this many many times in the past, so I didn't even think twice before doing it. Anyhow, I got the car towed to the dealer to have it looked at. So, if it is flooded, does the warranty cover the cost? Just wondering ...
Old Nov 19, 2007 | 10:51 AM
Old Rotor's Avatar
You said 3 and half years. Was it new or used? How many miles? Has it had all the TSB's? 4 years or 50,000 miles from first purches...
Old Nov 19, 2007 | 11:42 AM
chetrickerman's Avatar
if you are still under warranty, it is covered
Old Nov 19, 2007 | 12:29 PM
dntx5b9's Avatar
I am within the 4 years and 50K.
Old Nov 19, 2007 | 01:09 PM
then YES, it should be covered under warranty. Call Mazda Roadside Assitance @ 800-866-1998, have them dispatch a flat bed tow truck, take it to the dealership, and have them unfloord.
OR
You can use the DIY on the Tech section to do it yourself. If you've never had the starter / battery TSB recall done, then I might opt for the longer route of having your car taken in.
Old Nov 19, 2007 | 01:23 PM
dntx5b9's Avatar
There was a starter/battery recall? I don't think I got that one done. Where can I get info on that? The car is already at the dealer. Thanks!
Old Nov 19, 2007 | 01:27 PM
Never fear, Jedi is here.
http://www.finishlineperformance.com...48-06-1691.pdf
Old Nov 19, 2007 | 01:33 PM
good old jedi!!
Old Nov 19, 2007 | 01:36 PM
Originally Posted by chetrickerman
good old jedi!!
I help when I can, thanks.
Old Nov 19, 2007 | 01:40 PM
ken-x8's Avatar
Not actually a recall. Just a TSB, which Jedi has pointed to. You would normally not hear about it unless you had the problem and the dealer diagnosed it correctly.
Let us know which dealer, and how they wind up treating you.
Ken
Old Nov 19, 2007 | 01:43 PM
dntx5b9's Avatar
Cool! Thanks. Just talked to my dealer. He said everything is taken care of by warranty, but he said I would have to pay like pro-rated $20 bucks for the battery. My car is at 47K and 4 years and 9 months, so I guess I was close.
However, he said that my front brake pads are almost worn out and I have to replace. He also said that he will replace the rotors under the warranty so he recommended that I do it. Does that sound right? Thanks, again.
My dealer is Rosenthal at Tysons corner. They guy I go see there is pretty good. I've had bad ones at the same dealer, but so far so good with this guy.
Old Nov 19, 2007 | 01:54 PM
the prorated thing makes NO sense to me.
Not sure about the brake situation, since I've never seen rotors replaced under warrany @ 47,000 miles.
How much do they want to charge you for the brake job?
Old Nov 19, 2007 | 01:57 PM
dntx5b9's Avatar
$240 or $260 for the brake job. Is that a lot? I know meineke or midas do for a lot less, but I am not sure about that.
Old Nov 19, 2007 | 02:01 PM
dmc27's Avatar
doin' the bull dance
Can't say I've ever heard it, but it sounds reasonable. Expecting a brand new battery at no charge when the original has 47k on it is asking alot. It sounds like they're being pretty good about it.
Dealership prices are always higher, but that's not too bad for brakes.
Old Nov 19, 2007 | 02:02 PM
brake jobs have one of the highest mark ups of any service you can do to your car.
Are you mechanically inclined? You could always do it yourself in about an hour if you want. (getting the rotors turned would require some work though)
If you're getting a free pair of rotors out of it, might not be too bad to just have them do it.
Old Nov 19, 2007 | 02:10 PM
dntx5b9's Avatar
Ha, Ha. No thanks! I will change the flat on my own (although not on the 8), but that's about it. At least they will give me free front rotors.
Old Nov 19, 2007 | 02:16 PM
ken-x8's Avatar
Sounds fair enough to me. Dealer work on the brakes isn't cheap, but IMHO getting free new rotors makes it a good deal. Battery deal is also good...you'll be starting with a better battery and a fresh warranty.
Good to hear Rosenthal is treating you well. That's where I bought my 8, and I've been very pleased with how they treat me on service. I've been seeing Rob of the Purple Team, and he's really great.
Ken
Old Nov 19, 2007 | 02:21 PM
dntx5b9's Avatar
Cool. I see Bill on the Orange team. I actually used to see Rob, but somehow got switched over to Bill. I highly recommend Bill.
Old Nov 19, 2007 | 06:01 PM
240 is a bit expensive for brake job if you do it *outside*
For Dealership, it sounds about right.
if you ask me, I will 100% hit the *DO IT* button. Cuz free pair of rotors? not bad !
Old Nov 20, 2007 | 09:56 PM
Old Rotor's Avatar
I would be surprised if they give you free rotors, I bet they are just turning your old ones.
Old Nov 21, 2007 | 08:06 AM
dntx5b9's Avatar
Well, the work is completed and the rotors seem new. Nice and thick. But can't be sure because I never really paid closer attention to my rotors.
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
akagc
Aug 11, 2015 07:07 PM
cschoeps
Aug 6, 2015 12:44 PM
marc2820
Jul 26, 2015 10:47 PM
