vibration
Old Nov 17, 2007 | 07:32 PM
zainanwar's Avatar
mannerism
vibration
hello guyz. wenever I accelerate and the rpm goes around 5 then there is a shaking sound coming from the car. I.ve checked two other rx8 and it had the same problem too. its a very irritating sound like something is vibrating badly. if any of u had this problem then plz share it with me and plz tell the solution to it. thankx in advance
Old Nov 23, 2007 | 12:27 PM
RXJei's Avatar
rx8 drive hard
..... i've had a similar problem, my car actually kind of rattles a bit before I get to about 3K....... its irritatating as heck. only thing I can think of is maybe something is loose (exhaust,cat). I had the same problem on my a old car. it ended up beign a gash in between the exhaust pipe and the muffler. got it fixed at a welding shop for like $15. hope this helps.
another thing that I was thinking about doing the next time I take the car to the dealership, is have them check the motor mounts, because sometimes it seems like the shift **** shakes too much. I've actually had 1st pop out 1, i think it was my fault though. I was taking the clutch out when I realized the car was In 1st. the car went to shake but i quickly stepped on the clutch again and 1st popped out. so................ idk i gotta get that checked out. oh yeah also before i forget to ask do you have a squeack in your clutch??? my car has had one, it goes away and then comes back. its always there in the morning when I start the car.
RevMeHarder
Jun 1, 2026 02:30 PM
Jb4ker96
Sep 27, 2015 10:06 PM
RAE008
Sep 19, 2015 02:24 PM
patriotjj
Sep 13, 2015 08:09 AM
GrAfiX
Aug 24, 2015 08:08 AM
