WTD: Airbag ECU for JDM AT
Old Nov 17, 2007 | 02:05 PM
JDM_Racer's Avatar
May be someone can help me out here...I have a JDM AT RX8 in the UK which has developed an Airbag ECU Fault. Being JDM it only has two Airbags where as all UK models come with 6. Therefore I can't simply replace the ECU with another from here. It needs to be from a Two airbag car... Does anyone one know of a JDM RX8 being broken with an Airbag ECU available?
Getting desperate here
Old Nov 18, 2007 | 05:52 AM
foo77's Avatar
4th batch : Apr 03'
if i recall,you can't swap your ecu with other
Old Nov 18, 2007 | 06:00 AM
Spinning Sushi's Avatar
I <3 Sushi
If you swap the ECU's, your ignition/immobilizer system won't work thus you will not be able to start the car. There's alot of other fun stuff that won't work right as well. Hope this helps
Old Nov 18, 2007 | 07:02 AM
foo77's Avatar
4th batch : Apr 03'
^ i know about that, maybe you mis understand with those smile scratche and mis read what i told him can't swap hope that will help him out, not me
Old Nov 19, 2007 | 02:51 AM
JDM_Racer's Avatar
I think you both may have misunderstood. I'm not talking about the main ECU that controls engine (and other) functions!
It's just the SAS (Airbag) control unit.
Old Nov 22, 2007 | 06:34 AM
Zero_Rotary's Avatar
Double 8
i suggest you post this on the general issues section...you may find better luck there on help
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
extreme_rotary
Sep 30, 2015 09:53 AM
p8ntman442
Sep 23, 2015 09:18 PM
