removing headlights?
Old Nov 14, 2007 | 03:07 AM
nuke0907's Avatar
Never Blend In
how do i remove the housings? do i need to take the bumper off, or is it just a couple screws on top?
i have some haziness on the inside of my headlight lenses from water leaking in. since my warranty has already expired, i cannot take it in to get new ones. however, i found a place that will take apart my old ones, clean them up, and re-seal them better than stock. i can get a better deal if they are already removed from the car.
i searched the DIY and nothing came up except for replacing the bulbs.
Old Nov 14, 2007 | 05:53 AM
chrism's Avatar
Misfit Moderator TnC
the front bumper needs to come off because there are screws underneath it and near the corners
Old Nov 14, 2007 | 07:21 AM
nuke0907's Avatar
Never Blend In
well damn. i was planning on doing some other things while i had my bumper off, but i guess this will just be a test run til i can aquire more parts. thanks for the reply chris.
Old Nov 16, 2007 | 05:02 PM
N rider89's Avatar
^NieL
yeah its you have to take the bumper off. once its fully off, the bolts are fairly obvious from there.
Old Nov 16, 2007 | 05:50 PM
MazdaManiac's Avatar
You won't get to the haziness, however.
The lens face is double-walled and the haziness is out-gassing caught in between the layers.
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
