removing the throttle body??
Old Nov 12, 2007 | 09:40 PM
ARC.4.LYFE's Avatar
yes i searched..and no i didnt find anything.......
my 8 is experiencing many of the same symptoms as countless others ive read about have experienced
hesitation at take off
no "get up and go"
rough idle
these are the things i found to try and fix it
replace ignition coils
spark plugs
plug wires
clogged cat?
malfunctioning/dirty throttle body
so today i did the check on the throttle body..aka i removed the air duct leading to it and opened the valve w my hand..apparently it was supposed to shut quickly with a spring loaded like action...mine kinda slowly (not real slow but not quick either) shut.
basically i was hoping to find advice/tips on the removal of this expensive and apparently well designed part https://www.rx8club.com/showthread.p...+throttle+body
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Colon Terminus
Sep 8, 2015 07:23 PM
