Replacement rubber grommets for air filter box
Old Nov 6, 2007 | 11:17 PM
MrCairo's Avatar
I was putting in a drop-in K&N filter the other day and noticed that one of the rubber grommets for my Air Filter box was missing. It was most likely me since I've replaced the stock air filter already. So, does anyone here know where I can buy replacement grommets for the Air Filter Box?
My preliminary searches have turned up nothing and I've not talked to my dealership yet. I'm hoping that I don't have to replace the entire assembly for one grommet.
Thanks in advance.
Old Nov 6, 2007 | 11:51 PM
StealthTL's Avatar
Check the back of your rad, and the fans!
DANGER, Will Robinson!
S
https://www.rx8club.com/series-i-trouble-shooting-95/gentlemen-check-your-grommets-45395/
Old Nov 7, 2007 | 07:25 AM
MrCairo's Avatar
S
https://www.rx8club.com/showthread.php?t=45395
Yikes! Will do - thank you StealthTL!
Old Nov 7, 2007 | 07:54 AM
alnielsen's Avatar
I believe there was a TSB on this for the 04 models.
Old Nov 7, 2007 | 09:15 PM
MrCairo's Avatar
Update. . .
Well, thanks for all of the info. . . I removed the air cleaner housing and insulator and found that the missing grommet was not causing a problem (fortunately). If it wasn't for these posts I wouldn't have even thought it was a problem. So thank you very very much.
Anyhow, the TSB for the '04 models - are you aware if Mazda changed the design? I have an '07 and it is VERY easy to push the rubber grommets out. . .
ironj221
36
Jan 20, 2026 08:28 PM
05TR1CH
Apr 18, 2023 04:56 AM
uZu
Dec 30, 2015 12:35 PM
cschoeps
Aug 6, 2015 12:44 PM
MrORAN6E
Jul 24, 2015 09:32 AM
