Manual & Diff Drain Plugs
Old Nov 6, 2007 | 09:41 PM
Jasonawojo's Avatar
Quick question, I'm going to pick up some Redline MT-90 and 75w90 Gear Oil to change out the transmission and differential fluid as I believe my car still has the original (or really old!) fluid.
Will I need a torque wrench for the drain/fill plugs or can I get away with the one turn past tight that is generally used for oil changes?
Old Nov 6, 2007 | 11:16 PM
ken-x8's Avatar
You don't need a torque wrench.
One turn past tight? That's way too much. Maybe you do need a torque wrench after all.
Ken
Old Nov 7, 2007 | 03:08 AM
TrochoidMagic's Avatar
is adjusting valve lash
hand-tight then just do 1/4 turn to 1/3 turn to crush the new washer... or hand tight and 1/8 turn with the wrench if you use the old washer.
hmmm...kinda like the same thing for spark-plug with crush washer on my piston car.
but yeah, if you can't feel the difference between too loose or too tight....then get a torque wrench. just don't dial in 50lbs.
j/k...really, you don't need to waste soo much money and go overboard on the torquewrench. just handtight +1/3 turn, make sure its snug...you'll be fine.
Old Nov 7, 2007 | 05:51 AM
Jasonawojo's Avatar
Yeah, I meant one tug past tight. Thought it but didn't type it
Thanks guys!
drebbrnator
Dec 27, 2018 07:02 PM
TeslaMSI
Dec 10, 2015 01:10 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
cschoeps
Aug 6, 2015 12:44 PM
