Failed inspection because of gas cap
Old Nov 6, 2007 | 01:58 PM
ferris11's Avatar
Since I just moved to NJ, I had to get my car inspected here. My car failed inspection due to a "bad gas cap". As far as I can tell, the gas cap looks fine.
Has anyone else had this and did you just replace it? It seems that would be the easiest fix, but it doesn't make sense to me that the gas cap is bad.
Anyone else had the same entertainment from their local DMV?
Old Nov 6, 2007 | 02:06 PM
alnielsen's Avatar
How was this gas cap determined to be defective? I just went for my pollution test this morning and all they did was connect to the ODB connector and check for errors.
Old Nov 6, 2007 | 02:31 PM
SilverStreak's Avatar
If you didn't have a check engine light (CEL), then it may have been a pending code that was about to throw a CEL. In PA all vehicles from 1997 on no longer have active pollution checks (running on dyno with exhaust sampling), instead they check the OBD-II or CAN for codes that indicate malfunctioning pollution control systems. The CEL for gas cap P0442 would indicate that either the cap wasn't on properly or otherwise fails to seal, there was a TSB for gas caps on the RX-8. I had mine replaced due to frequent CEL under warranty. You can't tell just by looking at the cap. Best bet, get a new cap at PepBoys for about $15 and take it back in for inspection after a week of driving to ensure that the code is cleared. If you clear the ECU yourself, you still won't pass because you need a drive cycle showing in the ECU when they check it again. Hope this helps.
Old Nov 6, 2007 | 06:06 PM
Asmoran's Avatar
cap probably just wasn't on all the way. Take it off, put it back on, then try again.
Old Nov 6, 2007 | 06:08 PM
HERO's Avatar
take it to the dealer. I had a CEL come on about my gas cap and they replaced it under warranty.
Old Nov 6, 2007 | 06:27 PM
expo1's Avatar
He's as bad as Can
In New Jersey they remove the cap and stick it on some hose that checks to see if any gas vapors leak. I had that happen on my F-150. If you don't wish to deal with the dealer the cap cost less than $15.00 at most auto parts stores Stant part#10838
Old Nov 6, 2007 | 07:40 PM
rotarygod's Avatar
It's a rule that was created because a defective gas cap releases insane amounts of toxic fumes into the air and heats the planet up. Glaciers and the polar ice caps melt. Ocean levels rise and civilization as we know it goes extinct which in the end makes the environmentalists happy (assuming any of them lived) as everything will reach equilibrium again in a few centuries but humans won't be around to mess things up. All because your gas cap didn't seal properly. Get that thing fixed!
Old Nov 6, 2007 | 08:16 PM
alnielsen's Avatar
Hey, the east & west coasts will flood and we, in the upper midwest. will be sitting high and dry.
Old Nov 6, 2007 | 08:18 PM
DarkBrew's Avatar
Extraordinary Engineering
When do I get beach front property in this deal?
Old Nov 7, 2007 | 11:04 AM
r0tor's Avatar
i got a CEL a month of so ago because my gas cap wasn't sealing (cleared the CEL, tightened the cap... and it came back)...
see Tommy at Roesenthal for a replacement
Old Nov 7, 2007 | 11:16 AM
chrism's Avatar
Misfit Moderator TnC
my dealer replaced mine under warantee and cleared the code
Old Nov 7, 2007 | 12:08 PM
Cool
That's good. I like that reply.
By the way the sky is falling.
Old Nov 7, 2007 | 12:39 PM
ken-x8's Avatar
If it lands in the ocean, that will raise the water level even more.
Old Nov 8, 2007 | 02:16 PM
ferris11's Avatar
thanks
I'll just buy a new cap. I'm sure that it's nothing major, but I never got a code on the car.
NJ DMV screwing me again.
Thanks.
Old Nov 8, 2007 | 02:37 PM
XRX8X's Avatar
more then a Mazda
well i had a cell three times for a very small evap leak.(was not inspected at the time)and i thought it was my vac.lines to the gauge inside the car(it was not!)had it traced to the gas cap which failed the emiission test 3 out of five times tested(i work at a dealer and my inspector is the best won't charge me!!)took it to mazda and it failed 4 out of five trys and they replaced it for free under wro. go get your free cap and save your money for the good ole gas game coming to a station near you soon!!
Old Nov 8, 2007 | 03:55 PM
Icemark's Avatar
There is a TSB that replaces the gas cap for free...
Old Nov 9, 2007 | 12:13 PM
r0tor's Avatar
if your car is under warranty...
i didn't even bother because my car is out of warranty, and even if it wasn't by the time i spent making an appointment and then dropping the car off and either waiting for it or bothering someone for a ride to and from the dealer.... - its worth the <$20 to just do it yourself...
Old Nov 9, 2007 | 11:23 PM
Icemark's Avatar
At most a 15 minute swap at the dealer... if you don't have a CEL on. They called me and did mine free of charge and finished before I got through the first magazine.
Old Nov 10, 2007 | 12:22 AM
LabDad's Avatar
Doggie Style :)
You're still probably under emissions warranty which should cover this. Took less than 15 min for mine to be replaced too.
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Zube6115
Sep 30, 2015 12:57 PM
