Acquired a turbo but is it Suitable???
Old Nov 5, 2007 | 11:51 AM
Derex'8's Avatar
ReDuX
Question Acquired a turbo but is it Suitable???
As title stated found this turbo(Don't ask don't tell) and was wondering if it would be suitable for the renny?
I have reason to believe that this was originally for a diesel engine:Idunno: anyway
It's a Garret turbo
The compreesor reads A/R.60 AiResearch T04
The turbines inlet measures 1.15 and outlet's ID is 2.55 in...
hope this helps
Here are some pics
TIA for all the info!!!
Old Nov 5, 2007 | 11:54 AM
Kane's Avatar
Get a flow map.
Some better experts may know of the top of their head, but I would go get a flow map and see how it breaths. For my Turbo land Cruiser - the one I had laying around if for a diesel boat and it breaths in a very narrow part of the power band - but I don't really care for my purposes; for an RX8 you need one with a wide CFM efficiency range.
Old Nov 5, 2007 | 12:08 PM
Derex'8's Avatar
ReDuX
^^^Hah I can't even find a flow map for this turbo
I'm sure there are some formulas out there to figuring it out...
Thanks...need some more heads to chime in
Old Nov 5, 2007 | 12:12 PM
Kane's Avatar
I am calling BS; simply because I found a map (granted in Swedish) if a Triple K Volvo Penta turbo... it just took me a long time..... maybe try some more?
If not; I would slap it on a beater! For the Renny boosting at 10 lb/min of air or less all the way to 40-50 lb/min is the ideal; and not many turbo's do that.
Old Nov 5, 2007 | 12:45 PM
Derex'8's Avatar
ReDuX
(Damn Site)...Well how do I figure out the A/R on the turbine side?
Old Nov 5, 2007 | 12:55 PM
rotorocks's Avatar
RotoRocks Powered
Just of the top of my head, the size look OK. .60 AR on the compressor is what I'll be doing on my new system, when I get to it. (Damn, becoming a free man sure does offer a lot of distractions) What AR is the turbine?
Old Nov 5, 2007 | 12:57 PM
rotorocks's Avatar
RotoRocks Powered
Oh, should say on the turbine does it not?
Loks like in the .80 ish, by the size of it relative to the compressor.
Old Nov 5, 2007 | 12:59 PM
Red Devil's Avatar
What's the size of the compressor wheel, and the turbine wheel for that matter?
Old Nov 5, 2007 | 02:16 PM
Derex'8's Avatar
ReDuX
The compressor wheel is roughly 2.13 in and the turbine wheel is 2.52in
No A/R listed on the turbine
Old Nov 5, 2007 | 02:52 PM
Derex'8's Avatar
ReDuX
^^ inside the turbine inlet it reads 1.15
Old Nov 5, 2007 | 03:09 PM
rotorocks's Avatar
RotoRocks Powered
OK, so it's exactly the same sized turbo as what I am thinking of using. My turbine housing looks much bigger though.
So it won't give you a real quick spool. But on the other hand the turbo will be very unrestrictive. It all depends on what you goals are.
Old Nov 5, 2007 | 03:16 PM
chickenwafer's Avatar
Nope
It would work, but it's not going to be exactly "peppy", but you will be able to make some decent power with it.
Old Nov 5, 2007 | 03:45 PM
Derex'8's Avatar
ReDuX
much appreciated all
I'm going to have to catch up on some of your threads...
Old Nov 5, 2007 | 03:59 PM
Derex'8's Avatar
ReDuX
rororocks would you happen to have a compressor map for the turbo you plan on?
Old Nov 6, 2007 | 08:46 AM
Derex'8's Avatar
ReDuX
Yeah I will be swapping out for a smaller A/R on the turbine side...
Old Nov 6, 2007 | 08:55 AM
rotorocks's Avatar
RotoRocks Powered
Not sure about your manufacturer specifically, but you can easily find a T04B turbo generic maps. Just Google it.
Old Nov 6, 2007 | 09:05 AM
Derex'8's Avatar
ReDuX
Originally Posted by GTAW
Is this going to be your winter project?
Hah!!!..I can only hope....probably more like winter, spring, summer...
but yeah I still have alot more reading and research to do in the process right now of trying to source someone to machine me a turbo mani with slot for external wastegate...
Any ideas on what would be the ideal placement for this turbo in the engine bay?
Old Nov 6, 2007 | 09:44 AM
Kane's Avatar
Have you been over to the Esmeril Turbo Thread? That looks to be the easiest to fabricate for besides the Greddy and like sized ones.
Old Nov 6, 2007 | 10:09 AM
Derex'8's Avatar
ReDuX
^^^ Yup and I have even pm'd chris about fabbing up a custom mani for my needs just awaiting a reply..and this project will be go...My only concern with the placement of their turbo is it being right next to the PCM...
whether I'll be using a interceptor or stand alone has yet to be determined though...
Old Nov 6, 2007 | 10:34 AM
Kane's Avatar
I can do it for you..... you have seen my manifold work right?
Old Nov 6, 2007 | 10:45 AM
Derex'8's Avatar
ReDuX
....Uhhmmm funny thing, still tops my welding skills though....well 1st source fell through..I gotta couple more lined up
Old Nov 6, 2007 | 10:50 AM
Kane's Avatar
I can make it strong - just not pretty (nature of underwater welding training).
We only had scrap pipe to use to we had to improvise - plus our rules are no money and no measuring LOL
Ok, I will stop hijacking.
