Renesis
Old Dec 23, 2001 | 11:37 PM
BOOSTD 7's Avatar
RX8Club.com Founder
Renesis
How about somebody posting some specs and info on the new RENESIS engine? I don't have anything in a digital format, but I'm sure somebody does.
Old Dec 24, 2001 | 01:46 AM
RyanC's Avatar
Road and Track had a good article on the RENESIS engine. It actually had quite a bit of detail. I will try and see if I can get it digital.
Old Dec 24, 2001 | 03:17 PM
fc3s.org's Avatar
Rotary Engineering
I got a shot of it from SS4.
Old Dec 24, 2001 | 05:48 PM
Fc3sracer's Avatar
Wow that engine bay looks funny. I have that road and track article but its a printout that somebody copied for me.
Old Dec 26, 2001 | 08:54 PM
Toadman's Avatar
Nomad Mod
LOL The Evolve pic... crack me up..
Old Aug 30, 2002 | 11:45 PM
B-Nez's Avatar
Leading vs. Trailing Spark Plugs
Has anyone else noticed on the big cutaway Renesis picture that the leading and trailing spark plugs are vastly different? Not only are the plugs shaped differently, but the ports from the inside of the rotor housing are extremely different. Any hypotheses or data on that?
Also, on the side cutaway, the plug wires are connected to what appears to be a belted accessory on the front cover rather than a black box. Any idea how that's supposed to work?
Old Aug 30, 2002 | 11:52 PM
B-Nez's Avatar
Also noticed something else at the 2 o'clock position. I can't tell if that's a compression artifact where the threaded hole meets the inner surface or a tiny port of some sort. Oil injection? It's kind of an odd place to simply be a bolt-hole. All of the other bolt-holes stop an inch or two before the inside (except the plug ports).
On the top right of the picture, the alternator is attahced to something that is appropriately shaped like a rotor. Nice touch. What might that be? Crank angle sensor? From the RX-Evolv photo above, it almost appears to have hose attached to it, though. That'd be pretty lame if Mazda made the thermostat an epitrichoid rather than a circle!:p
Old Aug 31, 2002 | 11:12 AM
rototlewski's Avatar
Yeah now that I look at it that does seem a little odd. It might be oil injection. That might mean much better metering of the oil and more accurate too. Hey maybe (just speculation) when the apex seal goes past it lubes just the seal. I don't know but we'll see when it comes out. Damn you now I have another mystery about the engine I have to think about.
Old Aug 31, 2002 | 01:54 PM
Renesis Rex's Avatar
it could be alot of things. map sensor. direct-rotor-housing fuel injection. built in nitrous oxide jet. it could even be a built in compression sensor, so when the compression starts to go bad, a little light flicks on in the cockpit.
Old Dec 9, 2009 | 07:15 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Haha it's cool. I'll figure somethin out.
Old Dec 9, 2009 | 07:44 PM
DubbsLuvs8s's Avatar
What just happened?
Old Dec 10, 2009 | 02:17 AM
7yr 3month bump. i am sure that is the record...
Old Dec 10, 2009 | 02:20 AM
RyansRx8's Avatar
Brettward is/has a G
OOOOO i get it now this is before the rx8 even came out lol wtf old *** bump!
Old Dec 10, 2009 | 07:23 AM
dillsrotary's Avatar
jersey fresh
{dillsrotary starts crying}
Old Dec 10, 2009 | 08:46 AM
JinDesu's Avatar
went back to srsly broke
I bet he replied to the wrong topic
Old Dec 10, 2009 | 12:33 PM
Gr8Bullet's Avatar
Sorry must pressed the wrong thread or sumthing. My comp was acting up and being super slow. 7 years damn. My bad.
Old Dec 10, 2009 | 12:36 PM
EMart11b's Avatar
Bang Bang
Old speculative thread is old.
Old Dec 10, 2009 | 12:37 PM
Shijin-Kun's Avatar
Rotary Power!
epic old thread
Old Dec 10, 2009 | 02:58 PM
otakurx's Avatar
Rotorheaded Geek
in before lock :p
Old Dec 10, 2009 | 03:57 PM
renesisgenesis's Avatar
mod edit
I heard the Renesis is gunna have 250 bhp, i mean 238, i mean 232, i mean 228, i mean 210-220.
Old Dec 10, 2009 | 04:20 PM
maxxdamigz's Avatar
Baro Rex
Epic bump!
Old Dec 10, 2009 | 05:18 PM
TX
It has to be, I believe it's from the month the site was started.
Old Dec 10, 2009 | 05:24 PM
Cf05's Avatar
Not Faster Thn Ryans Spd3
lmao how did you even find this thread!?
Old Dec 10, 2009 | 05:27 PM
tiltmode43's Avatar
OMGITM!
Given how many motors have gone on the Series I renesis, this idea turned out not to be too off
