Intake blocking plate on Greddy upgrade kit
Old Oct 27, 2007 | 11:10 AM
turborx8's Avatar
Boost 4 Life
The Greddy EManage Ultimate upgrade kit is currently on back order. I am going to order the Interceptor-X EMS instead but its not really an "upgrade kit" because it does not include the intake blocking plate and 1/8" nipple that I need to weld into my charge pipe that connects to my wastegate.
Do I need to have a plate made and do these two mods before I install the Interceptor-X EMS?
What other "fixes" do I need to get done to make sure the Interceptor-X runs perfect?
Old Oct 27, 2007 | 11:48 AM
mysql101's Avatar
heh.
don't bother with the intake blocking plate. You don't need it.
Also you don't need the charge pipe nipple. You should look up "fix #2" for the wastegate source.
Int-x should be plug and play. You'll get around 255 whp with it out of the box. Increase the boost and get it tuned for around 280-290.
Old Oct 27, 2007 | 12:01 PM
turborx8's Avatar
Boost 4 Life
Originally Posted by mysql101
heh.
So why would Greddy include the intake blocking plate?
Also, the fix #2 is basicly the same thing Greddy includes in the upgrade kit. You plumb the wastegate to the turbo outlet pipe by welding in a 1/8" nipple.
How much should I increase the boost to stay at safe levels? 9psi?
Old Oct 27, 2007 | 12:59 PM
mysql101's Avatar
maybe our terms are mixed up. greddy says to attach a nipple to the rear of the charge tube (where most people attach the BOV). You don't need to do that.
Greddy includes the blocking plate because it's easier to tune. Also if you're sticking with the 6 psi that the kit was setup for, you don't need the additional air that opens up.
You can go 9 or 10 psi, but much higher and you'll get more heat than power. I have my boost controller for 6 on low and 9 on high.
Old Oct 27, 2007 | 01:21 PM
mysql101's Avatar
btw your website said you can't put gauges in the A piller, but you can. There's no airbags in that location.
Old Oct 27, 2007 | 04:09 PM
turborx8's Avatar
Boost 4 Life
Can you tell me where I can get an a-pilar pod for 2 gauges?
This is all I could find.
http://www.cftype.com/carbon_fiber/?...product_id=314
Old Oct 27, 2007 | 04:11 PM
turborx8's Avatar
Boost 4 Life
I was under the impression that fix #2 was EXACTLY that. Weld in a nipple on the charge pipe and run a tube to the wastegate.
RicerX1
Jan 11, 2016 05:59 PM
Paul_Y
Sep 21, 2015 02:23 PM
mattymack
Sep 6, 2015 10:33 PM
wayloco
Sep 1, 2015 09:03 PM
