can you twin turbo you rx-8
Old Oct 14, 2007 | 08:44 PM
blowinup's Avatar
I'm thinking for doing some kind of force induction but I heard with a greddy turbo kit you can't go over 7000rpm's but I was on the mazdatrixs site and they have 2 superchargers. So my question is what should I go with
Old Oct 14, 2007 | 08:52 PM
8 Maniac's Avatar
greddy just needs a few fixes to work well. Best if you replace the blower with something bigger. Twin turbo should be possible but no real reason to use it, single should work just fine. really depends on your price range and how much power you're looking for.
Old Oct 14, 2007 | 08:59 PM
mysql101's Avatar
who told you that you can't go over 7,000 rpm?
if you run the greddy kit at 6 psi, it will hold 6 all the way to redline. if you raise boost, at 7k the turbo doesn't flow to keep up with the engine demands, and so it peaks at 7 and declines slowly after that.
Check it out:
https://www.rx8club.com/attachment.p...3&d=1189649274
Right now there isn't a SC kit available for the RX-8 that would be overall better than the greddy (and the greddy is the lowest powered turbo kit available for the RX-8!). Just look at where the torque numbers are at 3,500 rpm, and compare to the SCs.
anyway, back to your question:
1. You can twin turbo your RX-8, but it's no more logical than it is to quad turbo your RX-8.
2. You can go over 7,000 rpm with the greddy, but you're going to see diminished returns. If this is an issue, drop the $1,000 and upgrade to a larger turbo.
Old Oct 15, 2007 | 08:57 PM
blowinup's Avatar
but what about a supercharger???
Old Oct 15, 2007 | 11:13 PM
Robbie's Avatar
You can twin turbo or supercharge any car. I believe MadDog is putting a custom twin turbo system in his 8 and he had shown some time ago that if he used twin GT20's he could get as broad of a powerband as a GT3071 while remaining in some better efficiency islands than the 3071. The question is do you want to put the money down to make a twin turbo system work?
Now people bitch about the Greddy not holding full boost to the redline, but they overlook some things:
It's a fun turbo on the street. It spools up quick and 280 whp on an RX8 will outrun a stage II Sti.
It gives the RX8 a much fatter torque curve allowing you to better exploit its great chassis.
It's still the cheapest route to go.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
RXFEVER
West RX-8 Forum
Sep 28, 2015 08:30 PM
czr
Sep 13, 2015 11:37 AM
