Mazda Rx-8 Rim Problems
Old Oct 10, 2007 | 08:40 AM
babyboychase's Avatar
Ok i have a total problem... The rims I like wont fit on my 2008 rx-8 because of my caliper is oversized..... i dont want to put bigger rims on it because i have brand spanking new tires on my 16" rims that just came off the car dealership........ Would putting a wheelspacer help me in my case to have a better selection of rims without spending a fortune? And I wanna stick with the 16......
Old Oct 10, 2007 | 08:42 AM
Also will it mmake my turning suck?????????????/
Old Oct 10, 2007 | 08:43 AM
Old Oct 10, 2007 | 08:56 AM
StealthTL's Avatar
Tire posts in the tire forum, please.....
Moved.
S
Old Oct 10, 2007 | 10:04 AM
architect's Avatar
Wheel spacers would only push the wheel away from the hub... it wouldn't increase clearance around the caliper. Take this time to upgrade your wheels. 16" rims on the RX8 look straight dinky.
Old Oct 10, 2007 | 10:36 AM
like architect saids.
it depends on what kind of size is the 16" wheels. our car has the 16" wheels option, so it fits with 16" wheels BUT your wheel might be too small.
so in the other words, forget about your set of 16" rims.
Old Oct 10, 2007 | 10:53 AM
CTrx8's Avatar
space for rent
didn't you already have this exact question moved to the wheel forum?
Old Oct 10, 2007 | 10:56 AM
Socr8tes's Avatar
16s?! If you can't afford decent rims, you probably shouldn't be buying rims at all.
Old Oct 10, 2007 | 11:41 AM
Silver_Surfer's Avatar
I4NI
Huh? Where did you get the 16"s from? Not your 8? "Came off the car at the dealership"? Need more info.....
Old Oct 10, 2007 | 12:33 PM
Revvittupp's Avatar
Base AT?
Old Oct 10, 2007 | 01:26 PM
BlueRenesis82's Avatar
Registered Tracker
Can you even get 16"s anymore? I thought that ended after the 04's models.
Old Oct 10, 2007 | 02:01 PM
TopGear8's Avatar
mkuhnracing.com
well, i have 18's. so my problem might be different than yours. but when i put my new brake pads in, with my aftermarket wheels already on, the caliper stuck out further, and the way my aftermarket wheels are designed, the inside of each spoke would grind on the outside of the caliper when it went around. so i got wheel spacers and it works fine now.
Old Oct 10, 2007 | 04:40 PM
Revvittupp's Avatar
MazdaUsa.com is your friend... 16's still the base wheel in '08...
Old Oct 11, 2007 | 02:12 AM
base auto..
Old Oct 11, 2007 | 02:13 AM
yep,
tard.
Old Oct 11, 2007 | 02:29 AM
paulmasoner's Avatar
Asshole for hire
Originally Posted by swoope
base auto..
i thought like the others that 16's went away after '04
mazda is notorious for misinformation on the website..?
Old Oct 11, 2007 | 02:33 AM
was at the dealership about 6 months ago. saw a new car with the same ugly *** 16" wheels.
i might be wrong, but..
http://www.mazdausa.com/MusaWeb/disp...ehicleCode=RX8
you have to click on the engine mech. to find the wheel size.
Old Oct 11, 2007 | 03:15 AM
Z1k RX8's Avatar
16's
I bought a brand new 2007 RX8 base model AT and it came with 16's on it.Right now I'm looking into getting some 19's.
Old Oct 11, 2007 | 05:40 AM
machfive's Avatar
Those 16's should be sent the way of the dodo.
Old Oct 11, 2007 | 06:01 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
16s??! On an 8?!! Can you post a pic so we can at least see what they look like?
Old Oct 11, 2007 | 12:01 PM
Revvittupp's Avatar
So should the slushbox they come with. At least they got a 6 speed and higher output recently, btu the early auto's should not be called rx8's. I have never in my life seen such a performance and driver enjoyment difference between manual and auto as in this car. I use to routinely steer peopel from the AT RX8 towards a 6. If yoiu can't row your own gears, this is not the car for you....
Old Oct 11, 2007 | 08:59 PM
I4NI
So if you got "The Big Brakes" with 18" wheels, whats the smallest wheel can you go? 17"?
Old Oct 11, 2007 | 09:01 PM
Registered Tracker
^ yep.
Old Oct 12, 2007 | 08:25 AM
DOMINION's Avatar
I don't buy Kool-Aid
Just get some 17" Enkei's. Super light and cheep and they make off sets for that size now.
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
michaelsk8er
Nov 9, 2015 07:06 AM
megaman
Aug 14, 2015 08:41 AM
MolecularConcept
Jul 26, 2015 09:09 PM
Belalnabi
Jul 17, 2015 07:48 PM
