NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
advice on going catless
Old Oct 9, 2007 | 09:22 PM
redD3vil's Avatar
im thinkiin about removing my cat or jus removing tha resonator and doin a 3in down pipe from tha cat back? in removing tha cat alone which is tha best mid pipe to replace it with?
Old Oct 9, 2007 | 09:25 PM
mysql101's Avatar
they're all just a pipe. so get whatever you can get a good deal on.
Old Oct 9, 2007 | 09:26 PM
RMZ290's Avatar
Don't do it in Mass or CT. The cops are really enforcing the any non stock exhaust is illegal in some areas. You get caught with out a cat by the wrong guy and the car leaves on a car carrier. You might get away with just punching out the insides and leaving it on the car.
Old Oct 9, 2007 | 09:30 PM
redD3vil's Avatar
so i cen jus do a 3in pipe all tha way back ? cuz theres alot of race pipes n mid pipe on different sites like the racing beat wun or tha turboXS does it make a difference?
Old Oct 9, 2007 | 09:35 PM
alnielsen's Avatar
If you get a 3" midpipe, like the TurboXS, it won't mate with the stock muffler system. You will need a catback that is 3" also.
A plain midpipe is too loud for most people. If you get one, I would suggest that you get one that has a resonator on it.
Old Oct 9, 2007 | 09:36 PM
mysql101's Avatar
catless midpipe with the stock exhaust is fine... but if you have aftermarket exhaust and catless, it is usually too loud (depends largely on the combo you pick)
Old Oct 9, 2007 | 09:41 PM
redD3vil's Avatar
so i cen take it to a muffler place and have them delete my cat and jus put a regular 3in str8 to my stock muffler?
Old Oct 10, 2007 | 01:22 AM
nuke0907's Avatar
Never Blend In
a shop usually will not do it since it is illegal.
Old Oct 11, 2007 | 12:43 PM
redD3vil's Avatar
thanks fer tha help i just ordered a mid-pipe from rx7store.com
Old Oct 11, 2007 | 04:59 PM
altspace's Avatar
Eccentric Shafting
Not unless you know the shop and pay in cash. (wink)
I had my Mustang 5.0 fitted with 3" catless pipes back to 2 triflow Flowmasters and long chrome tips. Damn that **** was loud.
But alas times have changed.
Old Oct 11, 2007 | 05:50 PM
Brettus's Avatar
Boosted Kiwi
true . I had an insert made up to go in the tips which makes it acceptable for me .
Old Oct 11, 2007 | 06:32 PM
nuke0907's Avatar
Never Blend In
i have the Agency Power header back on my AT. that thing is loud. it sounds good at idle, but when i get on the gas its raspy and annoying. i'm thinking putting another resonator on it might make it better. any advice?
Old Oct 11, 2007 | 06:48 PM
Brettus's Avatar
Boosted Kiwi
I'll post up what I did in a few hrs - it will help for sure .....
Old Oct 11, 2007 | 08:30 PM
shinka213's Avatar
Pettit fangurl <3
ive got a straight pipe...had it custom made at the shop that does all my work...they specialize is custom exhausts etc...
they charge me about the same as any of the others already made minus the install price..
as far as the sound goes, im also running with a borla and its not that bad at all.
a friend has the same exact set up but with the AEM CAI and its much louder than mine...there is a big difference just with the AEM..
ive got a K&N typhoon attached to my blower...even with that, ive got minimal engine bay sounds...
i say "go for it"
more whp too!!
Old Oct 11, 2007 | 10:20 PM
Brettus's Avatar
Boosted Kiwi
here you go .
These tip inserts dramatically reduced drone in the cabin and also cut down the noise outside . Best part they are easy to remove if you want to take it to the track or scare old ladies They don't reduce performance at all either (tested with scanalyser)
Old Oct 11, 2007 | 10:48 PM
James429's Avatar
James C. Arthur, RN
I am currently cat-less and it was the best move I ever made. I was in So Cal and found an ex-felon who spoke little English (Amigo) who simply cut from the down pipe back. I lost a lot of weight with that ****. I then had NO mufflers or cat. Took it home and was nearly friggin' deaf. Drove back the next morning and begged him to put on the least restrictive mufflers he had. Found two new magnaflow universal mufflers that "fell off the back of a truck." He did the whole job for only $310. Also, this guy was like an artist. He just eyed up underneath the car and mandrel bent the 2.5" tubing all the way back. SOUNDS HOT!!! I recommend it. Sure, it's illegal, but most fun things are. The only problem is the loss of torque. There's not much to lose. But I'm gonna' dyno it this weekend and see what all the HP gains are.
Michael Bryant
Oct 12, 2015 03:07 PM
Luke.s
Sep 30, 2015 05:57 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
Evan Gray
Sep 26, 2015 12:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
