Strange "scraping" sound
Old Oct 9, 2007 | 12:47 AM
thegodfather07's Avatar
Rotary 4 Life
Hey Guys. My 2007 RX8 has been making a strange "scraping" sound when ever I shift from park to drive or from park to reverse. It sounds like two pieces of metal scraping together for a quick second, kind of like the sound when you are scraping on a steep driveway. It has done this for a while now and thought I'd ask here before I hassle with the dealership. Any idea what it could be?
Old Oct 9, 2007 | 07:30 AM
ShinkaChicago's Avatar
I hate to say this my fellow 8 owner but your 07' RX8 may have a transmission problem. If you hear noise/clunking sound when u change gears coming from your vehicle’s transmission or your shifting is delayed, it may indicate that transmission parts are hitting together "abnormally". Normally functioning transmissions are virtually free of noise, when clean transmission fluid is lubricating the moving parts. I recommend u to take this 8 to the dealership ASAP, before your CEL comes out. Is your 8 brand new when u bought it or used?
Old Oct 9, 2007 | 09:50 AM
tajabaho1's Avatar
Destroying Threads
either your gears are messed up, or maybe there might be something loose, in your transmission, go tell the dealer right away before what ever the hell is loose in there knocks some more **** up and blow your tranny
Old Oct 9, 2007 | 07:15 PM
Rotary 4 Life
Hey guys, thanks for the response. The 8 is brand new and it only happens when I shift from park, but no other time. Forgive me for my ignorant question, but is the gear box located right below the shifter, or up by the engine? The sound seems like it is coming from the front of the car by the engine, but I'm not really sure. Perhaps, Ill have the dealership take a look at it this weekend.
Old Oct 9, 2007 | 07:21 PM
tajabaho1's Avatar
Destroying Threads
the gear box is located under the shifter ofcourse, a little left offset if I'm not mistaken, or was it right........damn I cant remember
anyhow, I know what you are talking about now, shifting from park and all, its this squeeky kind of sound and eeeerrghhhhhh thinging until u put it in gear right? that is possibly because you put it between P and R for too long, I had that happen too, but when I took out my tranny and put her back with new ATF it was gone, and yours is an 07 justt like mine, so nothing to worry about, after a couple thousand miles, your gears will be looser and the scraping will be gone, its jsut tight
Old Oct 9, 2007 | 09:40 PM
Rotary 4 Life
Oh ok, that makes me feel a lot better now. Thanks. Ill try shifting faster and see if it changes anything at all.
Old Oct 9, 2007 | 09:42 PM
tajabaho1's Avatar
Destroying Threads
yank that bitch!!! she likes it rough (litterally)
Old Oct 11, 2007 | 01:22 PM
Rotary 4 Life
One thing that I forgot to mention, which is probably pretty important, is that the scraping does not happen as I shift. It happens after I shift from park. It normally happens when I am in reverse and backing up and right before I shift into drive, the sound occurs. Any ideas?
Old Oct 11, 2007 | 01:29 PM
tajabaho1's Avatar
Destroying Threads
hmm, gear bearings still tight? is your car bought new? or has it have previous owner? I know what you are talking about, my car had that for the first 3-4k then it went away and never came back again, so I wouldn't worry about it, but if it starts to interfere with your driving in anyway, then you should check the AT fluid first, then go to the dealer because there might be something wrong with your gears and bearing, or maybe bad mounting or assembly
Old Oct 11, 2007 | 06:42 PM
Rotary 4 Life
Ok. ya, I bought it brand new. I am at about 3500k miles so I will just see what happens. Thanks for the advice.
Old Oct 11, 2007 | 07:13 PM
saffrizzle's Avatar
I've had my car since 17k miles currently has 45k miles. If I'm shifting to drive from park or reverse I have to stop the car completely, wait a second or two, then start moving forward, like the car is slow to go into gear. If you rev it before it kicks into gear after you shift to drive it will make a clinking sound back there like the rear is slow to catch on.The dealer told me that the rx8 transmission is slow at shifting. Could they be BSing me? I still have like 3k miles of warranty left so I wonder if I should take it to another dealer.
Old Oct 11, 2007 | 07:14 PM
saffrizzle's Avatar
Oh yea around 35k miles I changed transmission and differential fluids hoping to fix that. No difference
Old Oct 11, 2007 | 10:46 PM
Rotary 4 Life
Hmmmm. That doesn't sound right to me. I would have it checked at a few different dealers before the warranty is up. Maybe the sound coming from the rear has something to do with the rear differential. But I am not sure. Id get it checked out.
Old Oct 12, 2007 | 08:22 AM
saffrizzle's Avatar
I could pinpoint if it was the differential or not if I knew more about what the differential did. From what I hear I can tell it tries to grab on when I shift into drive and sometimes it slips?
Old Oct 12, 2007 | 08:37 AM
DOMINION's Avatar
I don't buy Kool-Aid
Most AT's I have had will do that. Always come to a complete stop when shifting from P-R-D or you'r tranny will not last long.
I see people all the time pulling out of a parking spot in R and well the car is still rolling back pull into D and go! I'm like wow. I'll never buy a used AT. Thats why I got mine with 12miles on her.
Old Oct 12, 2007 | 07:07 PM
u got that right!
Old Oct 12, 2007 | 09:49 PM
tajabaho1's Avatar
Destroying Threads
I am one of those bastards who does do that, that is why I am on my second tranny (thankyou mazda) and this is my 3rd flex plate and 2nd clutch pack (never use a "godly" clutch pack from those mustangs, they ******* suck dick, I'm not kidding, the OEM mazda ones lasts longer)
Old Oct 12, 2007 | 10:23 PM
saffrizzle's Avatar
Is it only rear wheel drive cars that are like that? I have an 88 civic and drive an 02 cadi sts sometimes and theirs are instantly in drive. the cadi is front wheel drive too
Old Oct 12, 2007 | 10:58 PM
tajabaho1's Avatar
Destroying Threads
no, actually, all cars man, you should stop them completely,because it puts unnecessary strains on the gear, but then again, I'm underwarranty
Old Oct 12, 2007 | 11:06 PM
saffrizzle's Avatar
lol
Old Oct 13, 2007 | 01:35 AM
RotaryP7's Avatar
Seriously.. FML..
I've had that happened to me.. I ignore it..
Old Oct 13, 2007 | 03:13 AM
tajabaho1's Avatar
Destroying Threads
yep, just ignore it, untill ofcourse 60k miles, then start complaining like ****
Old Oct 21, 2007 | 09:38 AM
DOMINION's Avatar
^Dude I would not talk about how you treat your car with all the Mazda people floating around on here.
They might tag your a$$ and get you with abuse next time you need a new Tranny.
Old Oct 21, 2007 | 11:45 AM
tajabaho1's Avatar
Destroying Threads
^ lol, that would suck, but all good
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
