New Brake Pads? Help.
Old Oct 7, 2007 | 05:35 PM
TopGear8's Avatar
mkuhnracing.com
Hey, i was just installing some new brake pads for my rx8. it has 18x8 wheels on it, their aftermarket not stock.
anyways, my problem is, the new pads were alot thicker, i got them on and thought everything was fine, i put the wheel back on, then spun the wheel, and the inside of the wheel spoke rubbed on the caliper. i didnt have this problem before because the pad was so thin. Is there a way to fix this?
Old Oct 7, 2007 | 05:47 PM
expo1's Avatar
He's as bad as Can
new pads cannot cause the wheel to rub on the caliper. Check your work over again. Did you replace the all the shims and guides? Correctly tighten the caliper bolt. New pads means you would of had to push the piston back into the caliper, how did you do this? What I am getting that that brand new, correct pads should not cause this.
Old Oct 7, 2007 | 05:52 PM
StealthTL's Avatar
Cool
Could happen, the caliper slides out quite a ways, and if the wheels are too small you got trouble......
Are the pads genuine Mazda?
S
Old Oct 7, 2007 | 06:39 PM
SouthFL's Avatar
Seems like wheel offset issues. What measurement offset is the wheel? It would say on the back of the wheel, labelled/stamped ET.
Old Oct 7, 2007 | 06:45 PM
TopGear8's Avatar
mkuhnracing.com
The offset is 42mm. the reason the wheel rubbed was because the new pad made the caliper stick out farther, the pad was installed correctly and everything.
i used a c-clamp to push the piston back into the caliper.
Old Oct 7, 2007 | 06:49 PM
StealthTL's Avatar
The offset measurement is only good at the hub, the back of the spokes can angle radically, we found this quite a lot when searching for a 17" wheel to carry snow tires.
S
Old Oct 7, 2007 | 06:53 PM
TopGear8's Avatar
mkuhnracing.com
right now what i did is just put the new pad in on the inside of the rotor. and the old one on the outside. when the new one wears down a little bit, i plan on putting it on the outside, and the other new one that has not been used yet on the inside of the rotor. because the thickness of the brake pad on the inside does not effect how far the caliper sticks out..Is this a good idea?
Old Oct 8, 2007 | 04:15 AM
no,
and get the to a brake shop..
Old Oct 8, 2007 | 11:09 AM
TopGear8's Avatar
mkuhnracing.com
Ok well i just got wheel spacers. i am going to put them on before i put the wheel on and it will give me enough clearance. is there a downside to wheel spacers?
Old Oct 10, 2007 | 01:59 PM
TopGear8's Avatar
mkuhnracing.com
Bump....^^^^
Old Oct 10, 2007 | 02:02 PM
StealthTL's Avatar
Put them on then find some nasty speedbumps, see if the tires contact the body.
S
Old Oct 10, 2007 | 02:03 PM
expo1's Avatar
He's as bad as Can
I am not trying to be a search ****, but there were too many threads to pick from. Do a title only search for 'spacers' and you will find a few on the subject.
Old Oct 11, 2007 | 11:45 AM
ahh.. not only whay stealth said but the extra weight is a disadvantage.
Evan Gray
Nov 24, 2015 01:00 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
GranTouTou
Sep 30, 2015 06:11 AM
