Engine light
Old Oct 13, 2003 | 07:00 PM
ridged84's Avatar
Engine light
Started the RX up and the engine light was on.The book said it could be the gas cap yep it was loose so i put it on the right way and the light is still on.The coolent is ok to.The car still runs good and everything seems fine.Do i have to reset anything to get the light to go off? This is kinda scary 700 miles and i get a engine lite! Of course its going back to the dealer but i was just wondering if there was something i should do to reset it .
Old Oct 13, 2003 | 07:32 PM
medcina's Avatar
The light will go off on its own after a few starts. It could take a day or two. If it bothers you, you can disconnect the battery for a little while to reset the ECU.
Old Oct 13, 2003 | 09:08 PM
Magnesium's Avatar
Lurking troll
Dealership told me that the light will not go out after a few starts. It has to be reset. He said that he doesn't know why they didn't have it on a timeout or reset.
Old Oct 13, 2003 | 09:28 PM
goodyrx8's Avatar
I had to bring mine to the dealer to be reset. The said there was a know issue and that Mazda would be releasing and updated version of the ECU software.
Old Oct 14, 2003 | 12:16 AM
Magnesium's Avatar
Lurking troll
right....
Old Oct 14, 2003 | 06:12 AM
tpryor's Avatar
They downloaded the revised software into mine last week. The tech downloaded it from their support site (I watched him). Download into the car took 5 minutes.
I had been having repeated CEL's for thermostat problems (one of the known issues), and the thermostat always tested fine.
Disconnecting the battery for a few minutes WILL reset your light - I have done it several times now. The code is kept in memory and can still be found by the dealer later.
Hope this helps.
Old Oct 14, 2003 | 09:44 AM
eccles's Avatar
Prodigal Wankler
You can speed up the process by hitting the brakes while the battery is disconnected, which drains the backup capacitor(?) within a few seconds.
Old Oct 14, 2003 | 06:44 PM
syntrix's Avatar
I like cheese!
If you do disconnect, then the dsc will flash at you.
It might take two starts with movement for the lights to go off.
Just an FYI!
Old Oct 14, 2003 | 06:49 PM
mikeb's Avatar
100% Italian
I also have had to reset my ecu
and got flashing dsc but eccles gave instuctions to set that also
Old Oct 14, 2003 | 06:58 PM
Gyro's Avatar
Rotary Abuser
Sorry if this question is dumb......but, Has there been an "Official" TSB on the RX8 as of yet.
My dealer Tech dept claims thay have no knowledge of ANY issues as of yet.
I mentioned things like Oil Pan redesign, New software from Mazda to fix bugs like phantom CEL's.
They look at me like I have 2 heads. If there is a new software version available from Mazda...I want it. God knows what else was changed after Mazda Japan found some bugs.
Also...I dont think anyone in the service dept has worked on a rotary before, damned if mine is the first.:o
Old Oct 14, 2003 | 07:03 PM
Magnesium's Avatar
Lurking troll
pics of the two headed monster please.
Old Oct 14, 2003 | 07:10 PM
mikeb's Avatar
100% Italian
I asked my dealer about the buyback and free service and he was "unware of that"'
some of these dealers---I swear
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
