rx8 owners of auto
Old Oct 13, 2003 | 01:25 PM
j-apex rx's Avatar
rx8 owners of auto
is auto good to drive as the stick and if any problems .
Old Oct 13, 2003 | 01:28 PM
Bankotsu's Avatar
I don't have a RX-8 yet so I would also like to know.
Old Oct 13, 2003 | 06:40 PM
stangmatt66's Avatar
North County Boi
Re: rx8 owners of auto
There are a lot of threads running around here about the AT. Run a search for them and you'll find all the information you'll need.
Old Oct 13, 2003 | 07:55 PM
Haris's Avatar
RX8 auto vs. 6 speed difference
6 speed is faster from start obviously since you can dump the clutch at certain RPM and this would be hard to achieve on auto. Auto also has 39 HP less and about 5 lbs. ft. of torque more. Both are similar at higher RPMs. With pedals it can be as much fun to drive as 6 speed. Maybe even more. Probably not any problems now.
Old Oct 13, 2003 | 07:57 PM
mikeb's Avatar
100% Italian
I have a auto and I have no problems thus far
I love the option to paddle shift if I choose
Old Oct 13, 2003 | 10:45 PM
myrx8's Avatar
I love my auto also, and I use the shifter.
Test drive one, you'll like it.
Old Oct 14, 2003 | 09:58 AM
asparapani's Avatar
I personaly think manual is better. If your gonna get a hig performance car like the 8, get it manual. The tiptronic technology as fun as it can be, is not devlopped enough to deliver the same amount of power.
Manual is the ONLY way to go with these cars to have the " true " drving experience.
Old Oct 15, 2003 | 02:04 AM
mikeb's Avatar
100% Italian
thats not "TRUE"
Old Oct 15, 2003 | 06:17 AM
asparapani's Avatar
Talking
Hi Mike. I see you have taken offence to your decision of buying a RX-8 automatic. Let me clarify my opinion first before getting invovled in a potentiel "thread fight", ahahahha.
j-apex wanted to know if auto was just as good as manual. The answer is YES the auto is just as good as the manual. Of course you understand when I say YES it's just as good as manual, that means that everything mechanical about the system from gear shifting to gear placement and timing (except for auto there is a slight delay) works fine and smooth and everyone is happy.
Now this all depends on how he wants to experience the drive. Does he enjoy the flaps? Or does he enjoy stick? That's all up to him. But to reinforce my opinion on the manual gear box, you will ALWAYS get more power out of the engine if you go with manual. It is the nature of the transmission. Yes, flapping the gears up and down are cool,convenient, and one day will probably be the choice of the masses, but right now the only way to get the maximum power of the 2004 RX-8 is by choosing a manual transmission.
Now as for the " true driving experience " that i mentioned, I still stick to this because drving a car does not just entail going from start to stop in a straight line. Drving includes cornering,braking,steering,stopping, all of which are easier to do and you have more control with a manual.
Question: Do you drive manual?
My comments:
If you ever drove this car with a manual gear box and had to take a corner at high speeds while using the engine compression to "control" your momentum then you will understand what I am talking about. You can never get that type of control or feeling with the auto.
You can use the argument that ferrari uses tiptronic technology, but that's a ferarri with their millions of dollars of R&D creating the perfect response tiptronic system. Mazda doesn't use state of the art tip tronic systems for the RX-8. It's just another way of selling the car and getting auto lovers a chance to sorta feel what a manual is all about. Which is brilliant from them and seems like the trend these days.
It's nothing personal to you Mikeb and your choice of going with auto. I'm just stating a fact about the reduced power of the auto version of this car.
It's all good bro!:D
Old Oct 15, 2003 | 06:47 AM
Haris's Avatar
No, that's basically an RX8 statement. Look at supras for example. Auto supras can outrun a manual one with average driver. There are many cars like that. If mazda put same engine in RX8, then it would be very close performance vise. Probably only about .5 sec.
Old Oct 15, 2003 | 08:04 AM
druck's Avatar
UK Owners Club
Autos will always loose some power in the torque converter, however a really good one can do faster chanages than a manual, which can make up for this when accelarating through the gears.
However you have to compare like with like, the RX8 auto is quite an old design with only 4 ratios. Despite the wide power band of the renesis that is going to be a big disadvantage compared to a 6 speed manual, even without the difference in HP.
If the auto had a more modern 5 speed box like the Merc units, it would be a much closer proposition, and more fun with the paddles.
Cheers
---Dave
Old Oct 15, 2003 | 08:29 AM
asparapani's Avatar
Thanks Druck
Old Oct 15, 2003 | 10:55 AM
North County Boi
Cheers
---Dave
Dave, if he was talking about a turbo Supra, he could be correct. An automatic on a turbo car allows the turbo to stay spooled while the car shifts. In a manual, you'd have to let off the gas to make the gear change, thus dropping turbo boost. I owned a 2001 VW Golf Turbo with the automatic and could take on manuals all day long. There's not much of a performance hit with the VW automatic turbos. As for others, I'm not sure.
I do agree though that if the auto RX-8 had 5 ratios and the same horsepower as the manual, the race would be pretty close.
Old Oct 15, 2003 | 07:58 PM
mikeb's Avatar
100% Italian
no problem asparpari
I agree with many of your points
Old Oct 15, 2003 | 08:59 PM
asparapani's Avatar
Wink
No P's BREEZE! (montreal street translation for no problem brother)
Old Oct 15, 2003 | 09:22 PM
myrx8's Avatar
It is still an RX-8 - lets all get along
Old Oct 16, 2003 | 02:35 AM
mikeb's Avatar
100% Italian
excatly
sometimes I think its AT vs MT
Old Oct 16, 2003 | 06:46 AM
asparapani's Avatar
I agree. It's still F****** FAST!
Old Oct 16, 2003 | 12:23 PM
Shocka's Avatar
WHAT.... YEAH... OK!
this is just my opinion and personal feelings.
manuals are more fun to drive.
i get alot of control out of the car that i wish i had when i drive my auto nowadays.
But here is a question my friend has an Auto/triptronic setup in his Jetta and it seems to just automatically change gears as it comes cloose to redline. Is this normal of all triptronic setups?
im not sure of the numbers exactly but for example if the redline is 6 at about 5200 rpms it switchs gears.
anyone with insight on this?
perhaps u auto rx-8 owners can tell us if this happens with the 8 at least..
Old Oct 16, 2003 | 12:40 PM
grogiefrog's Avatar
Yes, what RPM does the AT shift at?
Old Oct 16, 2003 | 09:03 PM
myrx8's Avatar
Right near red line if you don't use the automanual function.
I have used the paddles and have heard the little beep go off.
Old Oct 17, 2003 | 03:00 AM
mikeb's Avatar
100% Italian
I agree
car seems faster off the line when paddle shifting
Old Oct 18, 2003 | 09:02 AM
grogiefrog's Avatar
How does paddle shifting work? As well as the automanual function?
Old Oct 18, 2003 | 04:43 PM
mikeb's Avatar
100% Italian
paddle shifts let you shift which up and down functions that are located on the sterling wheel
Old Oct 19, 2003 | 07:44 PM
myrx8's Avatar
I don't like the paddle shifters on the wheel. I usually use the console shifter
