Door Panel Lights
Old Oct 12, 2003 | 10:51 AM
8th1der's Avatar
Door Panel Lights
Has anyone changed these lights? I just bought blue and red bulbs but not sure which ones I like better. The dash lights show blue but the majority of the lights in the car are red. Any thoughts or suggestions? I will probably go with red.
Old Oct 13, 2003 | 02:24 PM
mikeb's Avatar
100% Italian
I changed mine to red they use 194 wedge bulbs like the corners
Old Oct 13, 2003 | 09:43 PM
goodyrx8's Avatar
How do they look in red? The originals have an orange tint, right?
Old Oct 14, 2003 | 12:01 PM
jdaled's Avatar
I changed mine to red... dome light too, looks great!
see here
They actually look much more true red than the pic shows, and they look really nice with the footwell lights I installed this weekend. I'll try to get a couple pics that better show the whole interior with the red lights at night, and add them to the directory.
D.
Old Oct 14, 2003 | 12:51 PM
Omicron's Avatar
Personally, I'd go with the blue for a couple of reasons. First, the lights are there on the door to light your way as you step out, and red bulbs will make it harder to see the ground. Secondly, the lights are there as a safety feature when you open your door while parked on a street - they give an indication to traffic driving by parallel to you that your door is open. Red bulbs will not provide as good a visual warning to traffic as blue or white.
Finally, I'd also go with blue because it matches the way-cool blue gauge lights, which come on when you open the door to a non-running car... just like the door lights do. The red would be good if they stayed on all the time.
One question for you though: where did you get the colored bulbs? I think I'll do my door lights too. :-)
Old Oct 14, 2003 | 03:36 PM
mikeb's Avatar
100% Italian
blue is probably better for light
but my car is red so I had to do it
Old Oct 27, 2003 | 01:20 AM
sohcpunk's Avatar
can you guys post links to where to find these bulbs and the prices? I would like to change my dome light and door lights red also.
Old Nov 18, 2003 | 09:00 PM
my10ae's Avatar
Moderator
How hard is it to change the lights in the doors? Do the panel need to come off or can the light cover just pop off?
Old Nov 18, 2003 | 10:43 PM
RX-MEN-8's Avatar
Angry
Today I replaced the white bulbs w/ red ones on the doors, and the rear top courtesy light. But one big problem occured. On the drivers side all went well.. I removed the plastic covering. Pulled out the bulb as per manual and inserted the colored red bulb.. On the passenger side things went south.. I removed the plastic covering, pulled out the bulb, but when I attempted to push in the new one w/ minimal pressure -- the bulb and the attachment went inside the door!! I tried for over an hour to get the sucker out.. It is one of those things that you get close--but can't pull it out. I finally had to give up thinking I might damage something.. I tried to remove the panel to get inside, but it did not move.. I did not want to break anything, since I do not have a picture how to remove the outer door panel so I can "push in the socket/bulb from behind. (The red looks great to go w/ my newly added red footwell lights) Time to hit the service dept. for a little help..What a bummer!
Old Nov 19, 2003 | 01:05 AM
KTM-316's Avatar
what is the bulb number for the rear dome lights?
Old Nov 19, 2003 | 10:26 AM
huhsler's Avatar
Wait, I thought the clear corners used the 7440 bulbs??
Old Nov 19, 2003 | 02:51 PM
mikeb's Avatar
100% Italian
the side winkers use 194
Old Nov 19, 2003 | 02:54 PM
huhsler's Avatar
Thanks for the CORRECT info!
Time to hit my FLAPS, since my clear side markers are set to arrive on Friday. Woot!
Old Nov 19, 2003 | 03:12 PM
mikeb's Avatar
100% Italian
no problem
most of the car is 194 or 7440
Old Nov 23, 2003 | 10:18 AM
jkamen's Avatar
I put in blue bulbs all around the car. Definitely a bit dimmer but much more light than the red. I did the doors, dome, map lights, trunk light, license plate light, and the running lights closest to the Mazda emblem on the front of the car. I love it. I got my bulbs at Pep Bpys for $2.99 per pack of 2. Highly recomended
Old Nov 23, 2003 | 04:28 PM
RX-MEN-8's Avatar
The dealer fixed my little problem w/ the left door light. N/C. The red looks great. I left the map lights in white just in case I do have to read something, but turned them to off -- so when you open the doors, they do not automatically come on. I thought about the blues, but since my panel lights were red, the footwell lights added were red, I wanted to keep the theme.. I wish I could get the dealer added red footwell lights to stay on longer than the time they do. Anyone know how this can be done?
Old Nov 23, 2003 | 06:32 PM
Omicron's Avatar
Take the timer that they came with out of the circuit, and wire them directly into another light that comes on when you open the door then fades out in 15 seconds, such as the door lights. Or, wire them directly into power and a switch.
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
vapor2
Sep 19, 2015 05:33 PM
czr
Sep 13, 2015 11:37 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
