H2O pump + t-stat + silicone hoses
Old Sep 10, 2007 | 12:30 AM
d j's Avatar
d j
hukbong himpapawid
pics from my mazmart pump install...
silicone radiator hose/OEM t-stat/Mazmart H2O pump
after draining the radiator and the block, remove the hoses and H20 pump pulley. loosen the 3 pulley bolts before removing the belt (makes it easier)
remove the nuts and bolts that attaches the pump to the block and pull the pump out
OEM vs. Mazmart
installation is reverse of disassembly
after disconnecting the hoses, remove the nut and 2 bolts on top and sides of the thermostat housing
pry the part from the air pump injector (on top of the t-stat housing) to the side to remove the t-stat housing
remove and replace...
autobahn88/ebay silicone radiator hose, good fitment except for the hose that goes to the t-stat housing... yoiu have to cut it about 1/2" and muscle it in to make it fit. no biggie, 'cause i'm a machito
ensure that everything's torqued down and no extra parts, re-fill with coolant (NPG-R in my case)
...I drove the car around for a little bit but I wasn't paying atttention to my scangauge II (in a rush to finish my errrands) but I'll post my observations tomorrow after I get back from work.
Old Sep 10, 2007 | 12:34 AM
Spinning Sushi's Avatar
I <3 Sushi
Ebay hoses FTW! Nice write-up! Remember to post your opinions and results on the pump!
Old Sep 10, 2007 | 12:39 AM
MyEnemy's Avatar
About how long did it take you to finish the job?
Old Sep 10, 2007 | 12:43 AM
d j's Avatar
d j
hukbong himpapawid
I was taking my sweet *** time this morning, so I would say about 4-5 hours including breaks...
Old Sep 10, 2007 | 01:03 AM
AJ's Shinka's Avatar
Enthusiast
Nice write up. Not exactly sure what "machito" means but it still sounded damn funny.
Old Sep 10, 2007 | 01:28 AM
how many miles on the car???? those are the clearest looking omp lines i have ever seen.
and nice job and write up.
Old Sep 10, 2007 | 01:56 AM
d j's Avatar
d j
hukbong himpapawid
hehe, thanks! I just heard machito from the cheetos commercial over the radio.
thanks! currently, almost 47K miles on the car...
Old Sep 10, 2007 | 03:18 PM
kinchu007's Avatar
How much is the Mazmart part?
Old Sep 10, 2007 | 08:31 PM
savedsol's Avatar
Carbonormous
Since you made the Evans switch did you flush or drain the block? Also, what's the big a$$ radiator cap?
Old Sep 10, 2007 | 08:37 PM
d j's Avatar
d j
hukbong himpapawid
I paid $250 (shipped)
Old Sep 10, 2007 | 08:45 PM
d j's Avatar
d j
hukbong himpapawid
...so today was the first time I drove the car in a decent distance (75 miles, to/fro). it was fairly cool in the morning and I didn't notice any difference. On the way home, it was about high 70's to low 80's and during stop and go traffic, I noticed that the highest the coolant temp went was 189 except when I was at the drive thru wherin it went all the way to 209. Freeway temps were fairly low, highest was 186. I can't really tell if there was any increase in power but that would be a great bonus.
Old Sep 10, 2007 | 09:12 PM
d j's Avatar
d j
hukbong himpapawid
LOL, of course! flushed it with Sierra twice and than the prep fluid just to be sure. it might sound like an overkill but better safe than sorry.
...I think you just answered your second question
Old Sep 11, 2007 | 08:10 AM
Question,
What tools you used to take the Pulley out ?
Im going to do mine as soon as Paul send me the pump ... need to prepare you know.
and why did you replace your t-stat? broken ?
Old Sep 11, 2007 | 09:18 AM
d j's Avatar
d j
hukbong himpapawid
Originally Posted by nycgps
Question,
17mm deep well socket or shallow w/ extension to loosen the lower alt bolt
12mm for the tensioner, brackets and water pump
10mm for the 3 pulley bolts
...there's nothing wrong with the t-stat, I just figured I replaced it anyways rather than keeping the old one and end getting stuck on me. it's a $20 part so it's not that big of a deal, like I've said before... better safe than sorry
Old Sep 11, 2007 | 11:11 AM
savedsol's Avatar
Carbonormous
I'm not so sure I did. Help me out.
Old Sep 11, 2007 | 11:41 AM
it's a big @ss radiator cap rated for 18.5 psig (1.3 kgcm*2)
Old Sep 11, 2007 | 01:43 PM
savedsol's Avatar
Carbonormous
I suppose that's my question, why the need? I was under the impression Evans doesn't need pressure.
Old Sep 11, 2007 | 09:22 PM
d j's Avatar
d j
hukbong himpapawid
I removed the silicone gasket underneath the cap...
Old Sep 11, 2007 | 09:29 PM
staticlag's Avatar
The Professor
is that also the OMP modification?
Old Sep 11, 2007 | 09:31 PM
staticlag's Avatar
The Professor
also, what brand is that cap?, it looks pretty sweet if I do say so myself.
Old Sep 11, 2007 | 10:19 PM
d j's Avatar
d j
hukbong himpapawid
thanks! Not so sure about the brand, just got it from ebay... and yes, I do have the Sohn OMP adaptor
Old Sep 11, 2007 | 10:25 PM
ahhhhhhh,,
now the mop lines make sense.. ding ding ding...
Old Sep 11, 2007 | 11:13 PM
maybe I should replace mine as well :P
I thought it cost more.
Do you have the part numbeR? (my lazyness stops me from looking at the parts.pdf)
Old Sep 11, 2007 | 11:16 PM
NM found it on your picture :P
N3H-115-171 15.73
Pretty sweet .... Going for next day shipping ... maybe
Old Sep 11, 2007 | 11:58 PM
d j's Avatar
d j
hukbong himpapawid
LOL! I got mine from the stealership...
