West RX-8 Forum Serving CA, NV, AZ, HI
Recommendations for San Diego shop to install my Koni Sports?
Old Sep 8, 2007 | 11:51 PM
BAM0027's Avatar
I live in Mira Mesa. Anyone have a good shop to recommend? I've had estimates from $250 (unrealistic) to $800-ish (expensive?) to install all four. The higher estimate said doing the rears takes over half a day. I'd need alignment as well afterwards.
What should I expect? Thanks in advance.
Old Sep 9, 2007 | 12:12 AM
TheDosDog's Avatar
Recovered Modaholic
Having had mine in and out about 5 times, I can do all 4 in about 2 hours on a lift without rushing. The rears are no harder than the fronts and the alignment does not change (verified 2 times)as long as you do not remove the alignment adjusting bolts (See RB spring install instructions). I can't help you on a shop but I think anything over 400 would be outrageous.
Old Sep 9, 2007 | 05:07 PM
BAM0027's Avatar
Thanks TheDosDog. That's good to know.
Solidtrance
22
Sep 4, 2015 12:47 PM
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
AussieGray
Jul 16, 2015 03:58 AM
